Hydraulic Bloke wrote:Electronic 4 spd wont fit starter on wrong side plus the ecm (electronic control module) gets a signal from engine ecu and since you dont have one. Best bet is a T50d 5sp out of a late XF, EA onwards engines have starter on l/h side and use v8 bellhousing. If you want an auto go for BW40 or M51, the diffs in aussie built transits have XF pinions and crownwheels so find a good 2.92 , also they came in LSD
carnut1100 wrote:Will be looking into this a lot further shortly...just bought a '79 Mk2 twin wheel truck, picking it up tomorrow night!
Screams its head off at 80...
carnut1100 wrote:I'm near Hobart.
My truck comes with a spare truck for parts so I might pull the diff out of that and strip it down. Are Mk1 and 2 diffs the same?
