vauxhall 5 stud bbs alloys of a vauxhall carlton
Postby intransit89 » Sat Jun 13, 2009 5:23 am
i can get a set of 5 for 50.00 with car tyres tho
205/65/15
i could fit 225/70 15 van tyres? or 195/15s :?:
also i know transit 5 stud is 160pcd is vauxhall 120 pcd?
]so i need to get adptors made up?
also could i have them in studs with 14 mm so the tranny 5 stud nuts fitted?
not looked in to this yet!
but heres a pic
intransit89
Re: vauxhall 5 stud bbs alloys of a vauxhall carlton
Postby MinorMatt » Sat Jun 13, 2009 8:20 am
transit studs are 12mm
You could fit the 225/70/15 to em - but they wont have a suitable weight rating for your van and you will be giving the plod and vosa a green light to pull you over, have a good poke around your van then issuing a big fine!
Dont know vaux 5 stud PCD but I know a man who will
But they would look good :)
Postby GBBiker » Sat Jun 13, 2009 8:57 am
IIRC Vauxhall PCD is 112mm.
IMO, there is no way you will fit those alloys over the centre hub unless you drill out the centres of the alloys; which will then cause the problem of weakening the alloy because the original bolt holes will be so close to the hub hole. Hope that makes sense :?:
GBBiker
Wrong Again!
Postby MinorMatt » Sat Jun 13, 2009 1:48 pm
GBBiker - he will have to get adaptors made anyhow so the centerbore isnt that relevant (depending on the offset)
Postby intransit89 » Sat Jun 13, 2009 2:12 pm
MinorMatt wrote:GBBiker - he will have to get adaptors made anyhow so the centerbore isnt that relevant (depending on the offset)
true
intransit89
Postby Luke » Sat Jun 13, 2009 2:24 pm
are they 4 or 5 stud :?:
Postby intransit89 » Sat Jun 13, 2009 2:27 pm
Luke wrote:are they 4 or 5 stud :?:
5 stud with 205 tyres at mo but was thinking of putting my 225/70/15 tyres on for van rateing :?:
intransit89
Postby Luke » Sat Jun 13, 2009 2:28 pm
have a look on the wheels - they might not even have a weight rating on them :)
Postby intransit89 » Sat Jun 13, 2009 2:29 pm
Luke wrote:have a look on the wheels - they might not even have a weight rating on them :)
and that means?
a no no :( :?: :?:
intransit89
Postby Luke » Sat Jun 13, 2009 2:33 pm
they'll be ok BBS are a quality manufacturer and the crossspoke design is a strong one :!:
if they were a cheap alloy in this sort of design then they wouldn't be up to much on a transit :)
not saying AEZ are crap - just an example of a weak style :!:
Postby intransit89 » Sat Jun 13, 2009 2:36 pm
Luke wrote:they'll be ok BBS are a quality manufacturer and the crossspoke design is a strong one :!:
ok so might be good then?
now for the good part can i get 195 15 van tyres or 185/15
could even go mad lol
225/15s on rear :lol: and 195/15 on front :lol:
a big IF i can get van tyres in 195/15 :!:
intransit89
Postby Luke » Sat Jun 13, 2009 2:37 pm
with yours being a 190 you'll proberbly need van tyres - mines an ex minibus so i can get away with car tyres :D
whats the width of the wheels :?: need to be sure that the van tyres will go on ok :idea:
Postby intransit89 » Sat Jun 13, 2009 2:38 pm
also what hubs should i use i have a pair of front mk4 ones of a k reg
and a set from a mk5 m reg cant see the difffernce part from the mk4 caliper nuts have rounded of :roll: :lol:
intransit89
Postby intransit89 » Sat Jun 13, 2009 2:39 pm
Luke wrote:with yours being a 190 you'll proberbly need van tyres - mines an ex minibus so i can get away with car tyres :D
i know dave use to have a vauxhall carlton with the wheels but at the time i didint think and let the car go with the wheels to scrap
he says iam sure thay was 205/65/15 :wink: so might go on ok for the 225s 70 ones
intransit89
Postby Luke » Sat Jun 13, 2009 2:43 pm
it's about now you'll regret fitting the mk3 wings :lol:
have you actually tried the 5 stud hubs with the 15" discs and calipers yet :?: still dont know 100% that it'll fit :D
