While its hot....
While its hot....
Postby executivetravel » Thu Jul 02, 2009 9:11 pm
If you fancy aircon but want something to use when the engine isnt running, try this...
not cheap but cheaper than aftermarket engine-driven aircon..
http://www.vectorsystems.co.uk/Viesa/Vi ... ntpage.htm
executivetravel
Re: While its hot....
Postby mrgasoil » Thu Jul 02, 2009 9:33 pm
I see no prices on the site............ must be damned expensive then :shock:
If it's under £100 i'll have one :lol: :lol:
mk5 flareside with tail-lift GONE and will be missed!
Mk6 T350 LWB DRW dropside with tail-lift.
mrgasoil
Postby Luke » Thu Jul 02, 2009 9:38 pm
i think these are what all the malteese minibusses have :D
Postby psv-hgv-flt » Thu Jul 02, 2009 9:41 pm
run off batt power and u need f*** good batts, see these all the time on lorrie cabs, and too noisey too sleep when on :|
psv-hgv-flt
Postby executivetravel » Thu Jul 02, 2009 9:48 pm
12v or 24v, they have battery sensing to shut off if the voltage drops
£1000 a time
the ones i tried werent noisy
merc sprinter dealer fit proper aircon 311cdi - £1500 plus vat, engine driven of course
executivetravel
Postby GBBiker » Thu Jul 02, 2009 9:55 pm
Ford Transit automatic air con is way less than £1000 :!:
GBBiker
Wrong Again!
Postby executivetravel » Thu Jul 02, 2009 10:11 pm
GBBiker wrote:Ford Transit automatic air con is way less than £1000 :!:
depends how you go about it, ring a dealer for a retro-fit...
you may get the bits from a breakers for £300
the viesa price was fully fitted and warranted
executivetravel
Postby mrgasoil » Thu Jul 02, 2009 10:25 pm
I have a fan..... and stop for ice lollies ;)
well cheap 8) 8)
mrgasoil
Postby executivetravel » Fri Jul 03, 2009 9:09 am
mrgasoil wrote:I have a fan..... and stop for ice lollies ;)
well cheap 8) 8)
sucker
executivetravel
Postby madmark » Fri Jul 03, 2009 2:17 pm
dont show this to t280 chris he will want one on hisd roof!..............you cant beat a drop of aircon! :lol: :lol: :lol: :lol: :lol: :lol:
Postby executivetravel » Fri Jul 03, 2009 2:23 pm
heres a good idea............(you know how you get em...)
small fridge vans (escorst,etc) have 12v systems
if you could find one in a breakers and rob the bits.....
well, it sounds plausible!
executivetravel
Postby glenandemm » Fri Jul 17, 2009 8:43 am
ive been looking for something like this for my minibus as it has its own tropical temp in the summer,where does this bolt on to and it says it uses like 1-2 litres per hour so do you have to have a big water tank for it as well?
glenandemm
Postby executivetravel » Sat Jul 18, 2009 10:46 am
glenandemm wrote:ive been looking for something like this for my minibus as it has its own tropical temp in the summer,where does this bolt on to and it says it uses like 1-2 litres per hour so do you have to have a big water tank for it as well?
it uses a small water tank (approx 2/3 ltrs i think)
and you get a roof mounted bit too
check out motorhome aircon units too...
http://www.conrad-anderson.co.uk/aircon ... models.htm
ring AS Taylors transport at barton under needwood (by the A38) or your local agent (dont know where your based)
http://goliath.ecnext.com/coms2/gi_0199 ... ooler.html
executivetravel
