but is it poss that adaptors can be made to convert the studs from six to five as my van has six studs and i want to fit a set of landy wellers which are a standerd five stud your help is aprecated many regards chris
Luke wrote:best way would be to swap the hubs+ axle and redrill the wellers
AlanN wrote:I think it was Mark Bradley I was talking to at Transitmania about the 5 stud spacers he made, between us, we thought it would be a good idea to make a much thiner 6 stud spacer which you could use as a template for drilling and a reinforcment if spotted on the back of the wheel...
What do you think Luke!!!
Plus weld up the old holes
took me about an hour and half to do both fronts and i'd say the back a good sat morningturbovan wrote:Luke wrote:best way would be to swap the hubs+ axle and redrill the wellers
ive never changed hubs or axles before how long would it take or how much for some one here to do it for me seams like a misson
properly built adapters wont be the weakest linkginsambo wrote:On the subject of six stud adaptors...would a PCD step down from an 205mm Iveco 6 stud to 180mm Transit 6 stud be too inherently dangerous on a 3.5 Gross twin wheel Pickup if its all bolted up tight?...Or a back axle redrill, mod and balance going a bit too far? (All theoretical as I haven't tryed the transit wheels on an Iveco axle yet)![]()
ginsambo wrote:Oh yeah, I looked up some engine weights: 2.5Di 275kg (Minimum), Cologne (12V) V6 140kg...Hemi 6.1 220kg Also the 5.7 Hemis are getting 20mpg (UK gallon) Urban. One day!
AlanN wrote:ginsambo wrote:Oh yeah, I looked up some engine weights: 2.5Di 275kg (Minimum), Cologne (12V) V6 140kg...Hemi 6.1 220kg Also the 5.7 Hemis are getting 20mpg (UK gallon) Urban. One day!
Damm!!! Im gonna have to lower the front again when the V6 goes in
sounds about rightginsambo wrote:Luke - I got the 2.5Di weight from something you came up with in one of your posts!I think originally you were saying it was 300kg's.
