FredTransit wrote:Sorry (and I am with you on this one, want one) no 5 speed with an essex. OD is the way to go, if you find one from a pinto van swap the bell housing over from the 4 speed, I am not sure if you need the prop though.
crazygore wrote:are you saying I can use a scimitar gearbox with O/D and fit the transit side mount gear selecter plate?
crazygore wrote:are you saying I can use a scimitar gearbox with O/D and fit the transit side mount gear selecter plate? I thought somewhere I had seen a modded essex bellhousing that would take a 5 speed??? Where can I get some of those deep dish 70's Wolfrace alloys? they are sooo cool!
