ST Seats Fit
ST Seats Fit
Postby Kram 60 » Sun Dec 13, 2009 10:27 pm
I finally got around to getting the pictures and text together from fitting the ST seats.
I bought a set of ST seats from a breaker. I got the full set (front and back) for £280
Original ST mounting
http://s932.photobucket.com/albums/ad17 ... =2ajpg.jpg
Had to be removed
http://s932.photobucket.com/albums/ad17 ... t=3jpg.jpg
Bits cut off
http://s932.photobucket.com/albums/ad17 ... t=4jpg.jpg
Made new seat brackets (spacers)
http://s932.photobucket.com/albums/ad17 ... =4ajpg.jpg
Some of the equipment needed:
Stainless steel bar
M8 Allen bolts
13mm M8 nyloc nuts
http://s932.photobucket.com/albums/ad17 ... =4bjpg.jpg
I sourced the drivers seat base and used it for the new passenger seat.
http://s932.photobucket.com/albums/ad17 ... t=5jpg.jpg
I also sourced from a scrapyard longer seat belt mounting bolts and and spacers from a Fiesta.
http://s932.photobucket.com/albums/ad17 ... ent=5a.jpg
Positioning of 4mm mounting spacers to allow clearance for seat runner adjustment.
http://s932.photobucket.com/albums/ad17 ... =5bjpg.jpg
Drilled out (minding the battery terminals- using wood to protect).
http://s932.photobucket.com/albums/ad17 ... =5cjpg.jpg
Base drilled and prepared for drivers seat.
http://s932.photobucket.com/albums/ad17 ... ent=5d.jpg
Positioning of 4mm mounting spacers to allow clearance between base and seat adjuster.
http://s932.photobucket.com/albums/ad17 ... ent=5e.jpg
Passenger seat completed and ready to fit.
http://s932.photobucket.com/albums/ad17 ... t=6jpg.jpg
The other side of the passenger seat
http://s932.photobucket.com/albums/ad17 ... t=7jpg.jpg
Removal drivers side original floor mounted seat belt mount.
(ST seats have seat belt mounts attached to seat as standard).
To remove the passenger seat a special tool is required to remove the bolts.
Required is a Laser 7 piece 3/8” D and ½” D ribe bit set. The set comprises of M6, M7, M8, M10, M12, M13 and M14 bits. (More commonly used on cylinder head bolts). These fit all other Transit bolts as well. I bought mine from Halfords for £30.
Note: Torques are not strong enough, or good enough to do the job.
http://s932.photobucket.com/albums/ad17 ... ent=7a.jpg
Drivers seat removed
http://s932.photobucket.com/albums/ad17 ... t=8jpg.jpg
Drivers seat fitted.
Note: New seat belt mountings sourced from a Fiesta (£2 for the pair). Also, rienforced with 4mm plate spacer on inside of seat base, secured with a nyloc bolt and lock tight thread sealer.
http://s932.photobucket.com/albums/ad17 ... rent=9.jpg
Drilling seat belt mount on passenger side
http://s932.photobucket.com/albums/ad17 ... ent=10.jpg
I Used Allen bolts to mount the seat runner to the base with 4mm spacers. This was a lot easier than using a 13mm spanner and a conventional bolt.
http://s932.photobucket.com/albums/ad17 ... 10ajpg.jpg
View of mounting bolts on drivers seat base.
http://s932.photobucket.com/albums/ad17 ... =11jpg.jpg
The whole job was carried over a period of 6 hours (ones all the parts had been sourced and collected together.
The Haynes manual said that to get the passenger seat belt centre mount off a special Ford service tool would be needed, but the ribe set did the job.
I found the job a lot easier to do with the bulkhead removed.
Here are a couple of pictures of the job completed.
http://s932.photobucket.com/albums/ad17 ... t=F1-1.jpg
http://s932.photobucket.com/albums/ad17 ... ent=F2.jpg
Parts / equipment required
24 x M8 Allen bolts.
24 x M8 Nyloc bolts.
2 x metres of 4mm x 38mm flat steel bar to make brackets
1 x drivers seat base
1 x tin of black aerosol
2 x nuts and bolts (Fiesta seat belt mounting spacers)
1 x Laser 7 piece 3/8” D and ½” D ribe bit set.
I hope you have found this useful.
Kram 60
Re: ST Seats Fit
Postby Luke » Sun Dec 13, 2009 11:26 pm
nice one mate 8)
Re: ST Seats Fit
Postby linus » Mon Dec 14, 2009 10:02 am
Yes :wink: Thanks.
Linus
Life's too cheap to drink short wine.
Peace
linus
Re: ST Seats Fit
Postby hillman » Mon Dec 14, 2009 10:52 am
looks really cool :D
you could now do mine :D :D :D :D
hillman
hillman
Re: ST Seats Fit
Postby madmark » Mon Dec 14, 2009 2:12 pm
8) well done mate looks the nutts 8)
Re: ST Seats Fit
Postby bigmastif » Mon Dec 14, 2009 6:51 pm
thats smart that mate 8)
makes you wonder why ford didnt offer them as a option :roll:
they kinda ucked that decision up :lol:
bigmastif
Re: ST Seats Fit
Postby Baggers » Sun Mar 14, 2010 11:25 pm
Hi Kram 60. I am currently trying to source the parts to do this to mine. Did you retain the original van seatbelts and use the Fiesta female part on the seat? Where did you get your drivers base from?
Cheers,
Baggers. :wink:
Baggers
Sportvan Owner!
Sportvan Owner!
Re: ST Seats Fit
Postby Baggers » Sun Apr 11, 2010 6:12 pm
Thanks Kram 60. :)
Thanks to your pictures and guide I now have a set of these in my Sport Van. The only thing I have done different is buy the proper floor covering for a single passenger seat, as the seat base sits directly on the raised part of the floor on the passenger side and I didn't think it looked nice.
Other than that, very helpful guide.
Cheers :D
Baggers
Sportvan Owner!
Sportvan Owner!
