Tranist trailer Advice
Postby Wee Jim » Sun Apr 04, 2010 6:53 pm
Hey, I know its been done esp with the old BT fibre glass bodys but has anyone got any pics and advice on making a transit into a trailer?? I know the balance would be out but there must be someway to sort it allout.Any helpanyone???
Wee Jim
Re: Tranist trailer Advice
Postby Luke » Sun Apr 04, 2010 7:46 pm
ive built one on a bt back - like you say its nose heavy but not too bad :D i just mounted it on a cut down caravan chassis :D
what did you have in mind :?: using a transit panel van :?: :D
Postby Wee Jim » Sun Apr 04, 2010 9:24 pm
yeah luke was thinking of a mk6 swb van. Thought it would look good!! would the rear wheels be too far back on one of them??
Wee Jim
Postby sc_BK » Tue Apr 06, 2010 9:22 pm
Ratwood built one from a mk3/4/5, he has a thread on it here viewtopic.php?f=13&t=25294
There might also be some more photos about the forum from meets he took it to.
sc_BK
Postby dwright2104 » Thu Apr 08, 2010 2:35 pm
Iv been thinking of making a transit trailer for some time aswell. to match our minibus.
My thoughts were to get a swb semi-hi roof because our minibus is the semi-hi, remove the axle compeletely and put two trailer axles in so that it removes the nose being heavy. (this would mean quite a bit of work to panels and the wheel arch inside, but we know a guy thats good at panel beating.) then weld a bulkhead in securely to hold the front of the van sturdy once we chop off the A pillars. then chop it off in front of the bulkhead and fit an a frame to the front with coupling, and then make a fibre glass nose cone for the front to make the aerodynamics better.
I done a pretty shitty photoshop job of what it would look like with my previous thought of using a jumbo and chopping the roof down to a semi-hi here http://fordtransit.org/forum/viewtopic.php?f=30&t=51675
dwright2104
Postby 93fxdl » Mon Apr 12, 2010 11:38 pm
a bit of topic but how about making a trailer from a luton body along these lines
http://www.youtube.com/watch?v=56XL0TysIn0
i know alot of srengthening would be needed but different or what?
ttfn glenn
93fxdl
