MK5 swivel base for drivers chair
Postby alexthecheese » Wed May 05, 2010 11:35 am
After one of these so I can turn the seat around in my bus for stretching out when we're stopped. :P Any ideas if there's any about, or a base for a different van/chair that I can use? Had a rummage through the forums and Google but nothing stands out.
Cheers! :D
alexthecheese
Re: MK5 swivel base for drivers chair
Postby projectzip » Wed May 05, 2010 2:06 pm
I'm wanting to do the same thing, many members ive noticed on here use renault espace seats and make there own subframe or fabricate the old one to fit as the espace seats have swivels on the bottom.
The specific Swivels for the mark 5 from retailers are £170!
My Race Support Vehicle / Camper Project www.exit13.biz one off graphics to full race car livery's.
projectzip
Postby alexthecheese » Wed May 05, 2010 2:17 pm
yeah, exactly- not cheap!
Thinking about it, what about the handbrake? :oops: I'd have to relocate it... :roll:
alexthecheese
Postby AlanN » Wed May 05, 2010 2:24 pm
I only did the passenger seat as the steering wheel stops the drivers side turning more than 90 degress... Must be an early espace subframe as the later types are part of the seat
Postby madbri » Wed May 05, 2010 3:02 pm
take a look at dachres thread on his camper :wink: he got over the hand brake well neat
madbri
Postby projectzip » Wed May 05, 2010 3:37 pm
Ahh there ya go!
Alan is that a box around your frame or is it a box your chair is sitting on im a lil confuzzled
projectzip
Postby MONSTER 0NE » Wed May 05, 2010 6:33 pm
I have used the early espace swivels on both my front seat in my van (there are pics in my progress thread), but need to shorten the base to accomidate the extra height of the swivels. But since I have done mine I have spotted that the peugeot 806 has a better design, with the swivel sunk in the middle so the extra height of the swivel is a lot shallower than the espace ones if that makes sense.
MONSTER 0NE
Postby AlanN » Fri May 07, 2010 3:14 pm
I built the box around the old seat frame and put the swivel on top. The box is storage for tow rope, jump leads etc.. I had to add the box on the top to tilt the seat base slightly to make it more supportive
The swivel is between the arrows, plus a thin bit the that is under the carpet which is bolted up, you can just see a bolt thread sticking up...
Postby spudmab » Fri May 07, 2010 10:49 pm
MONSTER 0NE wrote:I have used the early espace swivels on both my front seat in my van (there are pics in my progress thread), but need to shorten the base to accomidate the extra height of the swivels. But since I have done mine I have spotted that the peugeot 806 has a better design, with the swivel sunk in the middle so the extra height of the swivel is a lot shallower than the espace ones if that makes sense.
what sort of year 806, does it have to be top of the range model
spudmab
Postby MONSTER 0NE » Sun May 09, 2010 12:55 pm
Hi mate cant actually remember what spec model it was, as it was partly stripped in my local scrappy when i saw it.
MONSTER 0NE
Postby Choppergeoff » Wed Jun 02, 2010 12:30 am
alexthecheese wrote:After one of these so I can turn the seat around in my bus for stretching out when we're stopped. :P Any ideas if there's any about, or a base for a different van/chair that I can use? Had a rummage through the forums and Google but nothing stands out.
Cheers! :D
Hi Alex. I've just fitted a pair of swivel bases to my standard captains seats , (both singles) using a pair of American aftermarket bases from a Chevy van.
I cut down the runners , reduced the slide handle , fabricated new base to the swivel, cut the standard seat frame down to use the hight and tilt levers.then welded the seat base to the top of the swivel. re-located seatbelt anchor
bit of paint
job done.
I can turn it through 360 degrees with a little messing .
good luck Geoff 8)
I don't do Standard and I don't do Normal...whatever that is
[url]Past vans [/url]1966 Mk 1 V6 3.0ltr Camper. 1982 Mk 2
9 or 10 Mk 3/4/5's
current ...Customised SHR LWB twin SLD Door Chopped roof Turbo D
Choppergeoff
Postby alexthecheese » Wed Jun 02, 2010 9:13 am
Cheers! :D
bit of paint
job done.
good luck Geoff 8)
Sounds like you know what you're doing! :lol: How did you get around the handbrake situation? Just put it down when you want to swivel that way? :?: What van do you drive btw?
alexthecheese
Postby Choppergeoff » Thu Jun 03, 2010 1:49 am
Hi Alex.
To turn the seat, I lower the seat height and adjust the back of the seat forward, with the armrests down. this allows the seat to pass under the steering wheel. I release the handbrake and turn the seat through 180 degrees. then pull the brake back on and wind the back of the seat to a comfortable position. simples.
the passenger side just rotates freely with nothing to hit.
as you asked .........
The van is a LWB SHR fitted with a 2.5TD and twin SLD (with windows) and very much a project under construction. It'll soon have a tailgate rear door , large alloy wheels and a custom grille.
Cheers Geoff
9 or 10 Mk 3/4/5's
Choppergeoff
