aircon
aircon
Postby j. hayward » Mon Jun 19, 2006 7:48 am
Does anyone know of a company who will fit aircon to an '04 petrol / lpg transit.
John
j. hayward
Postby xbox360 » Fri Jun 23, 2006 10:50 pm
I would like to Know if my 137 TDCI can be done and how much as well.
xbox360
Postby Valsheda » Sat Jun 24, 2006 10:56 am
I bet it would be expensive, probably cheaper to get a full sunroof fitted :P
Valsheda
Top Tourneo Owner
Postby nitroman » Sat Jun 24, 2006 3:13 pm
i spent loadsa time trying to find an aftermarket air con but all i got was silly qoutoes like £2000 plus! so i give up
nitroman
Postby davidat19 » Sat Jun 24, 2006 6:30 pm
I would think expensive would cover it, theres all sorts of bits need swapping.
I put some side deflectors on mine (99 lpg) so that was a bit cheaper, around £55 as I remember. You can almost hear youself think at 70 with the windows down.
davidat19
Postby davidat19 » Sat Jun 24, 2006 6:31 pm
With the dual fuels, the most important accesory is an lpg map and a Morrisons loyalty card!
davidat19
Postby j. hayward » Sun Jun 25, 2006 9:54 am
It seems you can buy a kit for a deisel at around £1400 plus vat but not for the petrol / though you can buy a mondeo kit ( same engine ) so obviously the only difference can be the compressor mounting bracket but no-one can be arsed to obtain that bracket as a separate item.
I do have one company who are looking into it.
John
j. hayward
Postby madmark » Sun Jun 25, 2006 10:53 am
:? unfortunatly its will cost loads to have it fitted! i would think you are looking at £1500 to £2000 :(
Postby AndyS » Mon Jun 26, 2006 8:03 am
I had Air con fitted to a Mk6 (55) at the dealer when bought it. They got in a air con specialist to fit a Eberspacher system this cost around £2000. The dealer told me thay had got the price down as they were having a number of them done. I cant remember how much I was quoted at first, but it was over £2000.
The job took 3 days (that what I was told) and buy the look of it, the whole dash had been removed. With an after market one you can have a heat exchanger fitted in the back as well.
The company that fitted it is Bon Air in Essex
AndyS
Postby Gsman » Fri Aug 17, 2007 10:11 am
Had air con (Eberspacher) fitted to a mk6 in Southampton for under £2k 2 years ago and I think its worth every penny. However I usually keep vehicles for 10 years.....
The dealer was efficient and very helpful and the installation has been trouble free. If anyone wants more info pm me.
Gsman
Postby Guy88 » Mon Aug 20, 2007 9:15 pm
My air con fitment has so far cost £150 :shock:
when its done it will be arout the £300 mark 8)
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby djswampy » Mon Aug 20, 2007 10:37 pm
Guy88 wrote:My air con fitment has so far cost £150 :shock:
Thats a mk5 though. This is for a mk6. They make it more complex being a newer van.
djswampy
Postby Guy88 » Mon Aug 20, 2007 10:43 pm
The AC still works the same. its just a different switch.
No mor complex than fitting it to an EPIC
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby djswampy » Mon Aug 20, 2007 10:48 pm
Isn't the engine different? Duratoque - DI.
The issue is getting the parts. They haven't broken enough mk6's yet for the parts to be available. But it is a good suggestion to see if there is a knackered mk6 in the scrappers.
djswampy
Postby Guy88 » Mon Aug 20, 2007 10:54 pm
thats just a mount and pully. Hardest bit would be the evaporator
but they are available new for about £200
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
