Pieces of steel for fixing my hole
Postby alexthecheese » Thu May 27, 2010 11:44 am
I have a hole behind the drivers seat on the floor where I can now see through to the floor. I dont think this is right, so I need to get another bit welded in.
Me granddad has a welder and is apparently pretty good with it, so I need to get hold of a piece of steel - it only has to be about 6 inches across.
Where do I get this from? Really dont have a clue. :lol:
alexthecheese
Re: Pieces of steel for fixing my hole
Postby AndyJ2506 » Thu May 27, 2010 5:38 pm
b and q do small pieces of steel if your desperate. Not cheap tho a piece of 1mm 250mmx500mm is about £15
Call 07739463511
AndyJ2506
Postby sidspop » Thu May 27, 2010 6:23 pm
An 8 x 4 sheet round here is about £25, shows what kind of mark-up B&Q have.
Search your local phone book for fabrication places, or small engineering works. Go and
ask for the foreman, and ask for a bit of off cut.
Failing that, and this is last resort, local car scrapyard with some tinsnips, and get some off another car
sidspop
Location: The Black Country (near to Brummagem, but not the same)
Postby StuartB58 » Sun May 30, 2010 6:02 pm
I get loads of steel from a local engineering company, normally just a quid or 2. I even had them order me 6 metres of angle iron and it was only a tenner.
Stu.
MK6 Twin wheel 2.4 in white
Ford where rust is NOT an option.
StuartB58
