BOB 24v cosworth scorpio engine conversion - can it be done?
Postby Luke » Fri Jul 16, 2010 2:35 pm
yes :!:
and here's proof :arrow: http://www.youtube.com/watch?v=QJ9ZNeEW ... re=related
looks like he has the full scorpio wiring loom in judging on the interior shots :D and i think it's an auto box with the manual stick on :D
Re: BOB 24v cosworth scorpio engine conversion - can it be d
Postby Luke » Fri Jul 16, 2010 2:38 pm
infact check out his other videos its got ifs 8) http://www.youtube.com/user/player554ka ... 0lz3jgHBJ8
Postby ripbuster » Fri Jul 16, 2010 2:44 pm
WOW!! 8) 8) 8) 8)
ripbuster
Postby Gavin » Fri Jul 16, 2010 2:53 pm
i was told, flatly, not long after here i registered here that it could not be done. but a little thought told me that was bollocks. if you've got a donor car you can take everything off that you need, not just the ecu but the pats transponder pickup round the ignition barell and the associated boxes, then get the key transponder code copied onto a blank and have it cut to your van. simples.
Gavin
Postby Luke » Fri Jul 16, 2010 2:56 pm
Gavin wrote:i was told, flatly, not long after here i registered here that it could not be done. but a little thought told me that was bollocks. if you've got a donor car you can take everything off that you need, not just the ecu but the pats transponder pickup round the ignition barell and the associated boxes, then get the key transponder code copied onto a blank and have it cut to your van. simples.
you get told a lot of things that arnt true i was told you couldnt redrill mk4 hubs :lol:
easier on a mk4 as you can fit the lock into the transit door :idea: i think somone on here was doing one and had the scorpio door resting up against the side of the van - somehow the lock is incorperated in the imobiliser and you needed to unlock it before starting it :lol:
end of the day gav you've got the better and easier one to do it on :idea: :D
Postby BROWNYS V6 » Fri Jul 16, 2010 10:17 pm
them front wheels look like 6 studders :shock:
BROWNYS V6
Postby Luke » Fri Jul 16, 2010 10:26 pm
BROWNYS V6 wrote:them front wheels look like 6 studders :shock:
yeah they'll be off a 150 or single rear wheel 190 :D all the same stuff except the hubs
Postby AndyG » Fri Jul 16, 2010 11:49 pm
They also said the same about the EPIC pump and my transmission :o :lol: :wink:
Postby bortaf » Sat Jul 17, 2010 4:54 pm
who told you that?
it's more difficult yes but not impossible :?
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
