mk5 duratorq conversion?
Postby glenandemm » Sun Jul 09, 2006 6:30 pm
does anyone know if its been done and how easy,i need a diesel to do taxi'in in and fancy one of these engines out of a mk6 to go in my smiley minibus or a turbo di out of a mk5 with different pump so i dont have to swap all the electrics, either way i need an engine that pulls better than my 2.5 di,it doesnt like hills especially with 15 people in,already done pump mods, any advice would be great,cheers
glenandemm
Postby AndyG » Sun Jul 09, 2006 9:16 pm
There's roomers that somebody has put a duratorque engine in their smiley but I'm yet to see if this is true :(
A turbo engine is a good idea as you know it'll be a perfect fit and you can use the '98 to 2000 Bosch pump and (if it doesn't already have) the 'blue' 100PS injectors :D
That should make it go :D without too many electrical involvements :D
You could even try and turbo your current engine :idea: There is mixed views on this as the compression ratio is slightly higher and could stress the old unit a bit :( But you've nothing to lose if the 'new' engine is on standby :?: :D :wink:
Postby AndyG » Sun Jul 09, 2006 9:23 pm
If you go down the electrical road and transfer all the electronics with the 100PS engine (not really advisable :roll: )You can buy a chip that'll up the output to 130PS :shock: That'll make those wheels spin :shock: :lol: :lol: :lol: :lol:
turbo conversion
Postby glenandemm » Tue Jul 11, 2006 10:32 am
i quite fancy converting mine to di turbo power,do i just put on a turbo manifold and oil pipes and tweak the pump,what about compression?
glenandemm
Postby 100ps_drw_hicube » Tue Jul 11, 2006 10:40 am
well there isnt much in difference of compression it has been ddone before also you will need the correct injecters to give more fuelling
100ps_drw_hicube
Transit Abuser!!
