Mk5 cosworth boa
Mk5 cosworth boa
Postby rob hall » Thu Jan 20, 2011 7:42 pm
Hi would the tank off a p reg petrol transit do for my boa conversion or will I have to still fit a swirl pot?
the welsh A-team!
rob hall
Re: Mk5 cosworth boa
Postby 24v » Fri Jan 21, 2011 9:06 am
The fuel pump must be lower than the tank to feed the pump.If not you will need a pump to fill the swirl pot which will in turn feed the injection pump under it.
Cosworth mk2 crew cab with IFS
24v
Cosworth Powered
Cosworth Powered
Postby Luke » Fri Jan 21, 2011 2:48 pm
does the mk5 petrol tank have a pump in the tank then :?: :D
Postby Gavin » Fri Jan 21, 2011 3:43 pm
mk4 does, cant see why the mk5 would be different
Gavin
Postby ginsambo » Fri Jan 21, 2011 4:42 pm
MK5 SOHC and DOHC has integral pump in tank, can't see the problem unless you use a diesel tank, in which case you need to fit a fuel pump.
MK3, eg V6 cologne has pump inline outside and below metal tank as I remember.
ginsambo
Postby Luke » Fri Jan 21, 2011 4:52 pm
ginsambo wrote:MK3, eg V6 cologne has pump inline outside and below metal tank as I remember.
yes thats right my mk3 v6 ambilance was like that :D
Postby rob hall » Fri Jan 21, 2011 10:39 pm
Thanks guys
Next question is the gearing on petrol transit dohc gearbox and 2.5di diffrent? If the are which is best
the welsh A-team!
rob hall
Postby ginsambo » Fri Jan 21, 2011 11:04 pm
Three types of gearings, only affecting 1st 2nd if I remember. W8, C8 and E8 are the codes on the boxes. W8 is wide ratio box used on 5.14 axle for heavy loads (tippers and the like). C8 is close ratio = better. Forget what the other is, think even better somehow...
I think 5th is universal being a 0.82 gear ratio...although 0.76 is on some car boxes, don't think its on any Transit boxes.
Anyway, I think the bellhousing on DOHC boxes and 2.5Di Transit boxes are different so you can't mount up with V6 adaptor plate with DOHC box. And SOHC (Pinto) used a standard 2.5Di box with a different adaptor plate again to mount to pinto. What code is on the sticker on the box?
ginsambo
Postby Luke » Sat Jan 22, 2011 12:19 am
rob hall wrote:Thanks guys
if you have a transit dohc mt75 that wont bolt to the boa :(
Postby rob hall » Mon Jan 24, 2011 9:21 pm
its was a pinto engine in the transit
:oops:
the welsh A-team!
rob hall
Postby rob hall » Mon Jan 24, 2011 10:13 pm
Can the pinto adaptor plate be modified to fit the v6? Has any one done this?
the welsh A-team!
rob hall
Postby Luke » Tue Jan 25, 2011 2:34 pm
rob hall wrote:Can the pinto adaptor plate be modified to fit the v6? Has any one done this?
yes it has been done - guy88 i think used one - have a search on here i think there are some pics and details :D not a straitforward job tho :)
would you consider the auto :?:
Postby rob hall » Wed Jan 26, 2011 10:26 pm
No im not a fan of auto
the welsh A-team!
rob hall
Postby rob hall » Wed Jan 26, 2011 11:05 pm
I might be mistaken here but I think I read that a transit van pinto flywheel can be redrilled to fit the v6?
Cz
the welsh A-team!
rob hall
Postby Gavin » Wed Jan 26, 2011 11:26 pm
i'm not going auto either, i drove my cossie granny about for 11 months and when i first got it i thought it was dog slow, all the hype about them being fast? nah, it was a big dissapointment. the auto box was designed to breeze execs about in comfort, all too keen to change up a gear, as an auto it was lazy and only showed its teeth in brief overtakes before climbing another gear all too soon.
Then i started driving it about in 2nd and 3rd on the stick, what a difference! sideways no11's everywhere upto 50mph, roll on, roll off, boot it, clouds of white smoke :lol: i blew the box to bits after a couple of months :lol:
manual all the way :wink:
Gavin
