xenon lights for a mk5
Postby redcube » Fri Apr 01, 2011 12:42 am
Will a xenon lights kit from a escort or any other ford fit a mk5 transit
I was thinking of this
http://cgi.ebay.co.uk/HID-XENON-LIGHT-C ... 20b5768df2
I would like xenon lights in my van and i can't find any for a mk5 transit but loads for ford escort and thought may be i could use one of them kits
redcube
Re: xenon lights for a mk5
Postby MrMPuk » Fri Apr 01, 2011 1:26 am
Transit uses H4 lamps.
Postby redcube » Fri Apr 01, 2011 2:28 pm
Then is there any other car that use H4 lamps that have a xenon kits available
redcube
Postby MrMPuk » Fri Apr 01, 2011 5:46 pm
redcube wrote:Then is there any other car that use H4 lamps that have a xenon kits available
Lots, just get a H4 kit.
Postby AndyJ2506 » Fri Apr 01, 2011 5:58 pm
will they be ok with the plastic lenses on a mk5 :?:
Call 07739463511
AndyJ2506
Postby Gavin » Fri Apr 01, 2011 6:08 pm
hid's run a lot cooler than tungsten or halogen...
Gavin
Postby MrMPuk » Fri Apr 01, 2011 6:11 pm
Would the laws in Ireland be different to here? As they obviously aren't legal here.
Postby redcube » Fri Apr 01, 2011 6:25 pm
The law here is odd at time but as i see it lot of cars have them so why not I'm going to look for a kit and install them i'm not out for the bright blue or any other color look just a crisp sharp white that will improve my lights at night
redcube
Postby AndyJ2506 » Fri Apr 01, 2011 6:26 pm
Gavin wrote:hid's run a lot cooler than tungsten or halogen...
only reason i said is the lights i have say theyre not suitable for HID's and they have plastic lenses. :?
Call 07739463511
AndyJ2506
Postby belly » Sun Apr 03, 2011 4:37 pm
My Connect was fine with HID's passed mot's too :wink: But yeh there technically illegal also the higher the number the less light they give and go stupidly blue :roll: i had a 6k kit in my connect which were good but ideally 4.5k/5k give better white light :D
belly
Kaiser Chief
Postby dirtydog » Sun Apr 03, 2011 5:32 pm
Technically illegal as they're not E marked bulbs, plus they're meant to have washers and self levelling. I've heard that it's being cracked down on at MOTs now.
There's a few different colours you can get some are not far off halogen colour and some are very blue-ish.
Also as your light pattern is dictated by your lense you may get a worse pattern and therefore worse light output.
I fitted an HID kit to my mk3 mondeo (which has clear light lense and uses reflector for beam) and I took it out after a week because it was crap, I ended up having to adjust the headlights right down to their lowest setting so that I wasn't blinding oncoming drivers etc.
If you want better headlights I would run them from a relay and get some decent bulbs like Osram nightbreakers.
dirtydog
Postby redcube » Sun Apr 03, 2011 9:18 pm
Ah well it seems its not worth the trouble I'm just going to get my roof bar sorted and add some 24V spot lights to that i don't want to piss of the law now do i :wink: :lol:
redcube
Postby MrMPuk » Mon Apr 04, 2011 2:18 am
belly wrote:My Connect was fine with HID's passed mot's too :wink:
That's because they aren't part of the MOT, but they will be shortly!!!
Postby chunky73 » Mon Apr 04, 2011 5:41 pm
What about fitting HID bulbs to spot lamps? Is that illegal as well? :idea: :?:
chunky73
Postby Mike » Mon Apr 04, 2011 5:41 pm
chunky73 wrote:What about fitting HID bulbs to spot lamps? Is that illegal as well? :idea: :?:
yes.
Mike
Wind up merchant!
