has anyone ever altered rear doors to fit 8x4 sheets in swb?
Postby dean_king » Thu Apr 07, 2011 11:31 pm
i am thinking of changing the rear doors on a swb mk5 so i can put
8x4 sheets straight in.
so i was wondering if anyone has ever done this or if there is anything
i need to know on the idea in general?
currently i have an ex-bt with bodywork issues but ive seen a silver mk5
that looks nice, 8 seeter so thinking, hmmmm.......
anyway, anyone any ideas?
cheers.
ImageMk5 lwb low roof! http://www.jdppropertymaintenance.co.uk (please click link to raise in google listings, cheers!)
dean_king
Re: has anyone ever altered rear doors to fit 8x4 sheets in
Postby MrMPuk » Thu Apr 07, 2011 11:32 pm
Would be easier to modify the bulkhead to make them fit. They fit without the bulkhead.
Postby dean_king » Thu Apr 07, 2011 11:52 pm
yes i guess it could, but that wouldnt fit eith my aims.
as i wouldnt want to get rid of the bulk head in my ex-bt
and if i got the other van i would want to keep 5 seats and
put a bulkhead in.
i think maybe i should have said that in the first place oops.
dean_king
Postby MrMPuk » Fri Apr 08, 2011 12:05 am
Didn't say get rid of the bulkhead, you could modify it.
Not sure how they would fit if you had 5 seats in the back.
Postby matthew2riches » Fri Apr 08, 2011 8:24 am
I think that is the only downside to a swb mk5..... not being able to fit an 8x4 in without modifying something. Oh.... and the rust :lol:
matthew2riches
Postby therawtradingco » Fri Apr 08, 2011 8:51 am
I got an 8x4 sheet in the back yesterday - i had to slide my seat forward a couple of clicks but it went in above the rear seats
therawtradingco
Postby MrMPuk » Fri Apr 08, 2011 8:59 am
therawtradingco wrote:I got an 8x4 sheet in the back yesterday - i had to slide my seat forward a couple of clicks but it went in above the rear seats
Handy to know. :?
Postby matthew2riches » Fri Apr 08, 2011 9:10 am
I had 30 sheets to collect for free and I could not get them in. Got some going corner to corner but the rest had to go on the roof rack..... very top heavy :shock:
If I removed my bulkhead I could get maybe 15 in laying down iirc.
matthew2riches
Postby dean_king » Fri Apr 08, 2011 6:39 pm
is there 4ft between the inner arches? or you mean over the top of them.
anyway, i think i am going to got this other van and the plan is to put a
box type affair in the offside rear door so i could carry half a dozen
sheets in the back without going corner to corner.
dean_king
Postby MrMPuk » Fri Apr 08, 2011 6:43 pm
dean_king wrote:is there 4ft between the inner arches? or you mean over the top of them.
If this other van has seats in the back, does it have a bulkhead? If it doesn't have a bulkhead then the sheets should fit.
Postby dean_king » Fri Apr 08, 2011 6:59 pm
i wouldnt drive a van with tools an stuff in without a bulkhead.
the bus im looking at has 8 seats in rails, so i can put a double next to the
side door. i will then put a bulkhead in behind them and round behind the
drivers side. then with an extended bit in the rear door i can get sheets in.
so all in all i will have 5 seats and van space for my tools and work stuff.
dean_king
Postby MrMPuk » Fri Apr 08, 2011 7:18 pm
They'll probably fit then if you are making a custom bulkhead.
Postby dean_king » Fri Apr 08, 2011 8:33 pm
i am the proud owner of an old van with a gazillion miles on her silver frame!
ex-working bus, so well maintained just lots of miles.
anyone want an ex-bt with bad rustworm to the body with t+t?
dean_king
Postby shippers » Mon Apr 11, 2011 2:20 pm
if your planning on keeping it n using it regularly for picking up loadsa 8x4 then y not put a frame on the side like window fitters use or if its only a one off then just slide them in from the back n ratchet strap the back doors shut
FINE SHINE MOBILE VALETING, covering durham and the north east, cheapest rates in town...fully trained and qualified by Autoglym. please call: 07835410432
shippers
Postby whitevanman66 » Tue Apr 12, 2011 6:19 pm
mine is swb but semi hi top..i have put some timbers across where that channel runs then a sheet of mdf on top,screwed into the rear timber to stop it moving.then a piece of 2x2 at the front to stop sheets sliding over my head under heavy braking.
whitevanman66
