Having enjoyed my Pinto-powered Mk4 (SWB hi-top part-camper conversion) for the last few months, the decision has been made that she is a 'keeper' - and that more power is needed!
I have started stock-piling the necessary bits for a V6 (cologne) conversion, so far I have the following:
* Full Engine, Loom & all Anciliaries (2.8 Efi (super-rare!) out of a pal's dad's old funeral limo - so v low mileage)
* Transit 2.9 SVO Flywheel
* Transit 2.9 SVO Radiator & all Water Pipes
* Transit 2.9 SVO Engine Mounts
* Transit 2.9 SVO Adaptor Plate & Starter Motor
I am planning to keep the existing MT75 gearbox, prop & diff that's already in the van.
I know I need to get hold of the following:
* New Clutch Kit - does this need to be a 2.9 Transit kit presumably?
* Efi Petrol Tank & Pump
I have read that the Granada exhaust manifolds and downpipes cause an issue (they don't clear the bulkhead and/or Transit gearbox?) - am I correct in understanding that Capri 2.8i Janspeed tubular manifolds will cure this?
I am hoping to do as little 'fabricating' as possible. On this basis, what else will I need?
Many thanks in advance for your help!
Cheers, Baggers.
