Standard Wheel Refurb
Postby labtec104 » Wed Jun 29, 2011 1:22 pm
Hi guys im knew to this site. So Hi. lol
I recently started my own business and have a Ford Transit 280 SWB in white.
There are a lot of rust patches which I am really determined to sort out as it makes the van look so much older than it is.
First, The wheels are in a right mess rusted completely. I want to start a project but i am new to all of this. There is so much rust on wheels that i had to chisel the spare wheel away from the holder.
So basically how do i start? lol
I have most tools and i have a fair idea but need reassuring.
Shall i sand down with a wire brush? Heavy duty sand paper? once i have sanded down to the metal on the wheels do i just put an anti rust primer on first?
Thanks :D
labtec104
Re: Standard Wheel Refurb
Postby Luke » Wed Jun 29, 2011 1:26 pm
easyest way would be to have them shotblasted :idea:
but transit wheels arnt exactly rare and it would problebly be cheeper to find a decent set and just paint them- even get a set with tyres so you have some spares :D
Postby labtec104 » Wed Jun 29, 2011 1:37 pm
Hi mate. Well im definately going to paint them. So two of the five wheels i have are really bad but the other three just look quite messy.
I want to repaint them. Should i start by wirebrushing the loose crap off them. then sand down and add a coat of some sort of rust prevention?
Once that is done do i just then simply paint and laquer? Im not after the perfect finish as they are only steel wheels - but i jst want them to look fresher :D
Also what colour would u recommend? or keep normal?
labtec104
Postby fedup2 » Wed Jun 29, 2011 1:52 pm
A wire brush in a drill might make the going easier.
Launch x431 owner ;)
fedup2
Postby labtec104 » Wed Jun 29, 2011 1:58 pm
fedup2 wrote:A wire brush in a drill might make the going easier.
Dremmel will do the job yeah?
labtec104
Postby fedup2 » Wed Jun 29, 2011 2:32 pm
suppose it would but a drill might be a bit stronger.
fedup2
Postby isla motorsport » Thu Jun 30, 2011 12:48 pm
hi we refurb about four sets of wheels a month. what i suggest you do is flat the wheels down with an 80 grit production paper and when the wheels are flatted down enough apply an etch primer just a couple of coats then using a scotch brite (red) when dry lightly flat the wheels down then apply several coats of primer if 2 pack primer only 3 coats but if using rattle cans 5-6 coats letting them tack off in between coats when finished flat them down with 7-800 wet and dry Let them dry then you can paint them. Some wheel silvers come ready to use dont have to use clear coat to obtain a shine. Also dont forget to mask up the tyres and valve stem. Cheers Ivan
isla motorsport
Postby labtec104 » Wed Jul 06, 2011 11:53 am
Hi im going to start today as i have a couple of days off.
I am going to use a wire bursh drill part to get the excess rust off.
Then smooth off with some decent grit paper.
Do i need to use some sort of rust free primer? or can i just go straight on with my normal paint primer?
Thanks, andy :D
labtec104
Postby Altransit » Wed Jul 06, 2011 12:03 pm
labtec104 wrote: Do i need to use some sort of rust free primer?
:? Did you see the helpful post above your last one :?:
Postby labtec104 » Wed Jul 06, 2011 12:10 pm
actually i didnt lol :?
thanks.
labtec104
Postby labtec104 » Wed Jul 06, 2011 12:21 pm
I have normal silver wheel spray. but i also have white.
its a white transit, should i keep the wheels silver or do i go above board and paint them white? i havent seen this before on a transit but am eager to here opinions. :mrgreen:
labtec104
Postby Scotty86 » Wed Jul 06, 2011 2:50 pm
One of our members "scbk" painted his wheels white, they look good.
2017 Transit Custom SWB RSV
Scotty86
GLX Posse
Postby labtec104 » Wed Jul 06, 2011 3:03 pm
arhh mate they do look good :) :D
I quite like the rim around the bottom of the van too, maybe in black though rather than red. I will definately think about that as there is so much bodging up ive got to do around the lower of the van and arches due to rust. that may be worth a shot.
Cheers :mrgreen:
labtec104
Postby transit300 » Mon Jul 11, 2011 8:52 pm
[quote="labtec104"]arhh mate they do look good :) :D
tou always see them in black red looks nice diffrent i dont think the look as nice in black around the bottom
mk6 transit 2001 swb 2.0td. 300
transit300
Postby gravelrash2004 » Wed Jul 13, 2011 11:09 pm
black around the bottom makes them look like they are covered in underseal - imo
good luck with the van and keep us posted with pictures
My Projects
150S :- DOHC 2.0 EFI (115PS), Ratio: 5.14
viewtopic.php?f=27&t=66682&start=15
viewtopic.php?f=27&t=97579&p=829640#p829640
gravelrash2004
