frank308d wrote:Yahoooooo....
My mate has just rung me and it seems I am now the owner of a sensible mileage 3.5ltr Holley carbed Rover V8 !! All complete, running sweet and I get everything with it, dmanifolds, downpipes, rad, coil, wiring, the whole shooting match.
Now, do I keep the ??77 box, make up new mounts and have my prop altered to suit or try and get an adapter plate and keep my MT75?
Should have the lump etc home by the end of the summer which gives me a goal to get the bodywork in order....
Now, where did I put that chain link steering wheel?
AlanN wrote:Hmmm, do love a V8, but I think my V6 is bad enough for fuel comsumption
rover wrote:frank308d wrote:Yahoooooo....
If you keep the Mt75 you will need to cut into the front crossmember to allow enough room for the bottom pulleyIs the box with it auto or manual? I personally would (we did) modify the bulkhead slightly to allow the engine to go further back, this way if its auto you can use the original rover rear mount and a 6" piece of drilled angle iron and mount it straight to the standard MT75 crossmember. You would stll need to have the prop altered to suit!
i have yet to see a rover v8 on a mt75 transit box!
We made some custom mounts for the V8 to utilise the Mk3/4 transit di engine mounts. Luke may still have these and if so a small donation to the forum project fund would save you a lot of hassle![]()
The downpipes won't fit, you will have to make some/ alter the ones you have.
Use your existing rad and mounts as the top hose on the V8 will reach almost perfectly.
frank308d wrote:There is a 5 speed LT77 box with it. Is it more straight forward to keep that box and make up new mounts? I was expecting to have to modify the tunnel to accept the engine. Still need to chop into the front cross member?
Talking to a mate about it today and he raised the issue of gearing. My Mk4 190 has, I think, the 5.14? diff, with the LT77 box in front of that, would I still be able to hit 70-ish or would it be screaming its nuts off at that speed?
frank308d wrote:Saw my mate last night and he said to use the later R380?? gearbox. Stronger and a better gear shift. Only thing is he said the box has a splined shaft on the rear to pick up the transfer box but.... Seems sure that an LDV prop has the correct end to pick up to the shaft? Any ideas LDV boys out there? I know I'd have to have a lwb prop adapted to fit the new set up of course.
Cheers
Frank
