My mk6-7 Front End Conversion photo album
Re: My mk6-7 Conversion photo album
Postby Davidreidy » Thu Jul 28, 2011 8:16 pm
well looks like ur the man when it comes to getting my front end converted
the only part i dont understand is? head lights (with mk6 indicator holders) i can get hold of 2 x wings with indicators on the side of the wring with mine been a big van my indicators stick out not like urs near the mirror as urs is a smaller van
any other advice or parts i may need?
Azuzas Removals - Man&Van Hire - Removals - House & Shop Clearence - Collections & Deliverys
Azuza Paint & Decorators - From a Rail to a full House to a full office or shop.
Davidreidy
Postby stephenferguson » Thu Jul 28, 2011 8:20 pm
indicator holders that go into the headlights, hard to explain but u'll see what i mean when you start...
2008, VW Transporter T5, T30, 6 Speed 130, Reflex Silver.
2006, 100 T280, MWB, Mid Roof, Moondust Silver. SOLD
Mk6-Mk7 Facelift Photos Here
stephenferguson
Postby Davidreidy » Fri Jul 29, 2011 9:38 am
so when im searching for parts on the internet or ringing people up what do i tell people i need sorry that im stupid but im still learning lol cheers for ur help.
do u know any good places where i can get mostly all the parts.
i can get 2 x wings in white and drivers side headlight for £75 including delivery but these wings are for jumbo vans or lutons tippers u know where they have the indicators built on the wing? ok cheers.
Davidreidy
Postby MrMPuk » Tue Aug 02, 2011 1:05 am
Davidreidy wrote:i can get 2 x wings in white
Wouldn't worry about the colour as the white is totally different.
Postby oldyellar » Wed Aug 24, 2011 10:27 am
Why wasn't Rome built in a day?
Becuase I wasn't the Gaffer!
oldyellar
Postby CHRIS S » Sun Sep 04, 2011 9:21 pm
WHERE DID U DECIDE WHERE TO WELD THE CRASH BAR MOUNTS?
CHRIS S
Postby stephenferguson » Sun Sep 04, 2011 9:27 pm
do you mean the end of the chassis legs? I welded the plates all the way around. but made brackets and welded them inside the chassis legs first.
stephenferguson
Postby CHRIS S » Sun Sep 04, 2011 9:45 pm
Yeah on end of chassis legs. how did u no how far up or down to weld them? to get the postition right?
CHRIS S
Postby stephenferguson » Sun Sep 04, 2011 9:49 pm
you buy the plates from fords, if you bolt all the panels on first to align everything up before weld, the headlight surround panels bolt to the plates. I also i had a mk7 transit to measure off next door, thats the best way to do it.
stephenferguson
Postby CHRIS S » Tue Sep 06, 2011 12:23 am
So take it its self explanatory when were building it then?
CHRIS S
Postby stephenferguson » Wed Sep 07, 2011 11:41 pm
Yes mate its quite straight fwd, specially with the inner wings and rails. Best bet is to have a mk7 to get measurements off and use genuine panels.
stephenferguson
Postby kevinwalkerjnr » Sun Sep 11, 2011 3:38 pm
stephenferguson wrote:i took 15mm of the outside, cant remember the inside measurement but there straight, i measured off another mk7 off holes in the sides of the leg, then the lips that i cut off i welded back on the sides. i bought the proper support that slides inside the leg for the tow eye on the passenger side.
I bought the plates that sandwich between the leg and the cross beam, i welded those top and bottom, then bolted the crossbeam through the sides of the plate and the lips that i welded back on, just copied the original mk 7 as much as i could.
i have a part to fit under the bonnet tomorrow which tunnels the air through into the cab and then i'm gonna take the finished pic and add it to the album.
Regarding this part, I have not sourced as of yet. Does it Conner to existing.
http://i1202.photobucket.com/albums/bb3 ... D-orig.jpg
kevinwalkerjnr
Postby stephenferguson » Sun Sep 11, 2011 4:48 pm
which part mate that link shows a transit?
stephenferguson
Postby kevinwalkerjnr » Sun Sep 11, 2011 5:41 pm
stephenferguson wrote:Here are the pics to how i have done it, any info needed just ask.
http://s873.photobucket.com/albums/ab29 ... onversion/
I just put the bumper on today and mounted the under bonnet parts correctly, so i'll get a pics added tomorrow.
Hi, regarding the under bonnet work what was necessary to buy and do !! Cheers ;)
kevinwalkerjnr
Postby stephenferguson » Sun Sep 11, 2011 5:53 pm
Hi,
There is a black plastic tunnel that bolts to the scuttle panel, it has a rubber seal attached to it which seals with the bonnet when shut, and the back of it clips into another plastic panel which attaches to the bulkhead, you need both these parts for the air intake to work correctly. not sure of part numbers tho.
stephenferguson
