Front brake upgrade mk4 swb
Postby Luke » Fri Oct 20, 2006 10:51 pm
as many of you know im fittning mk4 front to my mk1, im planning on reconditioning the whole lot and was thinking while im at it i could upgrade the brakes :D
Looking through the speedways catalogue i can see the mk4 6 stud have a 270mm disk over my 5 studs 254mm disk :D all the dimettions are the same thickness etc. infact the only dimetion different is the o/d :!:
http://www.speedways.co.uk/front-c8917.html
Has anyone tried this :?: bolting a 6 stud disk to a 5 stud hub - is the mounting PCD the same :?:
also looking at the calipers they look very similar in design :!: are they the same :?: what are the differences :?:
anyone any info to add :?:
Re: Front brake upgrade mk4 swb
Postby Sundowner » Sat Oct 21, 2006 3:56 am
Luke wrote:Has anyone tried this :?: bolting a 6 stud disk to a 5 stud hub - is the mounting PCD the same :?:
I have 6 stud discs on my 5 stud hubs :D but its a mk2
Sundowner
Postby Luke » Fri Nov 03, 2006 1:51 pm
Sundowner wrote:I have 6 stud discs on my 5 stud hubs :D but its a mk2
basically i want to do exactly what you've done but to the mk4 :D
I guess by the lack of responce no-ones tried it :(
Does anyone know if mk4 6 stud twin wheel disks and calipers are the same as mk4 6 stud single wheel disks and calipers :?:
also is the stub axle the same on twin 6, single 6, and single 5 stud :?:
and if anyone (local) has got any knackered ones for me to try it with it would save me wasting my money if they dont fit :D but if it works i'd buy new ones anyway :D
Postby rover » Fri Nov 03, 2006 3:07 pm
I can see exactly what you want to do Luke, but I've never seen it done so cant be of any help there. Hasnt Tony got any six stud stuff laying around at his place?
Rover.
rover
Postby transitgeoff » Mon Feb 12, 2007 5:07 pm
the disc mounting pcd is the same :D
transitgeoff
Postby Luke » Mon Feb 12, 2007 7:44 pm
transitgeoff wrote:the disc mounting pcd is the same :D
so the 6 stud hub is the same and the offset made up on the caliper or are the hubs different :?:
this is looking promising 8)
Postby transitgeoff » Mon Feb 12, 2007 8:18 pm
well the hubs are different cos one has 5 wheel studs and one has 6 :roll: both discs are mounted to the hubs with 5 bolts and the pcd is the same, thats as far as we went today :D we think the stubs are the same but havent checked as yet :D
transitgeoff
Postby Luke » Mon Feb 12, 2007 8:21 pm
i meant stubs :oops: :lol:
Postby Luke » Thu Feb 15, 2007 9:50 pm
well geoff :?: :P
Postby transitgeoff » Thu Feb 15, 2007 9:55 pm
busy, busy Luke but havent forgot(yet) :D
transitgeoff
Postby Luke » Tue Mar 20, 2007 11:52 pm
taken from another thread :D
Aragorn wrote:either fit 270mm vented lwb disks and the caliper carriers (calipers are identical)
Postby Luke » Fri May 18, 2007 6:19 pm
just to confirm this :?:
i can fit the larger (270mm) caliper carriers and brake pads to my smaller(254mm) calipers - and fit 270mm disks :?:
easy as that :D
Postby Aragorn » Fri May 18, 2007 9:14 pm
the calipers are the same part number so yep that should work just fine
Aragorn
Postby Luke » Fri May 18, 2007 9:21 pm
Aragorn wrote:the calipers are the same part number so yep that should work just fine
nice one 8) cheers
now one more thing (gets complecated) with the larger carriers in will the smaller pads still fit :?:
as they look similar :?
Postby transitgeoff » Fri May 18, 2007 10:42 pm
well if your gonna use the smaller pads what was the point of fitting the larger discs?? you will still have the same braking area :? just fit the proper 190 pads :roll:
transitgeoff
