Mild steel box and rectangle section
Postby Brustkle » Sat Aug 11, 2018 1:48 am
Anyone know where I can find the right dimensions of box section for a mk5 transit chassis cab.
Mines is rotten and needs replaced, But any suggestions on where I buy remanufactured box from ?
My Smiley is called Rarity :D
Brustkle
Re: Mild steel box and rectangle section
Postby bigjohnthomas » Sat Aug 11, 2018 8:40 am
It's a top hat section spot welded to another top hat section
A seedy back street sheet metal works will be able to fold you up for a packet of fags
Bit of oversized top hat bish bosh slip it over :wink:
bigjohnthomas
Postby gotgcoalman » Sat Aug 11, 2018 3:03 pm
The newness has worn off a bit :wink:
Most small engineering places will either have or fold the bits you need for a few quid.
ok in your case quite a few quid due to the amount needed.
It's a case of cut a section out and measure it then get it made up.
Too bloody quiet :shock:
gotgcoalman
Return to Transit Talk
