by Airthies » Mon Dec 22, 2025 12:34 am
If it's only for ford then there's no point buying anything other than Forscan.
Factory level access and cheap for what you get.
Basic program download is free for reading codes as you only pay for the cable which can be between £35-75 depending which one you go for.
Otherwise it's a Subscription for extended licence (after the initial free period when you register an email).
But if you're likely to only need the extended licence options rarely you can register another email address for another free period. But a subscription is not expensive.
Downside is that the best platform to run it from is a windows laptop though there are other basic options for android or apple via Bluetooth adapter.
If you're doing more than ford then you'd best do your research on which brands are covered and to what extent for the brands you may require it for.
2008 350LWB 115PS ex fitters van "retired"
Bikes, yes, a few bikes.
V86+patchV86.04X-ProgC81
