bulkhead fixings
bulkhead fixings
Postby essex iain » Mon Dec 31, 2007 4:55 pm
ive bought a bulkhead for my new van. to fit it i need to either use nuts and bolts, as i havent got the original captive nuts. are they still avaliable from fords?
they fit in to a hexagonal hole, and provide a thread for the bulkhead to bolt in to.
i can nut and bolt down the sides easily enough if necessary, but the floor holes seem inaccessible from the underside. if i cant get bolts through the floor im a little concerned it may not withstand weight hitting it when i brake very well.
essex iain
Re: bulkhead fixings
Postby MrMPuk » Mon Dec 31, 2007 4:59 pm
You don't say what year van this is but the captive nuts for Mk5, 6 and 7 should be avaliable from Fords and not very expensive.
Postby essex iain » Tue Jan 01, 2008 12:17 pm
sorry forgot to mention this is an m reg smiley. went to fords and ordered fifteen to get me started at 99p each. that should do each side and across the floor hopefully.
essex iain
Postby djswampy » Sun Jan 20, 2008 2:14 am
There is that, or you could of used self tappers straight through the floor.
djswampy
Return to Transit Talk
