are there any rules on where the tank can be fitted in a vehicle?
all the lpg vans ive looked at have the tank in the loadspace, on the floor behind a solid bulkhead, and then boxed in with ply, which uses up a large amount of the available space
i'd rather see it under the van - where there is plenty of space, or if its got to be inside - hung from the roof, so at least i can use all the floorspace.
if its possible to mount elsewhere, what would be the likely cost of having the tank moved?
thanks..
