and another rebuild
and another rebuild
Postby karl » Tue Oct 14, 2014 3:19 pm
started another one today for a forum member loss of power,erratic idling and loads of blue smoke :(
so here it is statrted this morning with me helper being me dad :D
so after striping it out and pulling it down to the block we found a hole in piston number 2 it has
you can just see the hole inside the bowl under the crack
you can see here the were some of the piston has stuck to the bore
turned bores to half way a filled to see if the rings or piston sizes are shite
karl
Tranny Lover!!!
Re: and another rebuild
Postby belly » Tue Oct 14, 2014 3:27 pm
belly
Kaiser Chief
Postby blue estate » Tue Oct 14, 2014 3:34 pm
FOOKED :(
blue estate
Postby karl » Tue Oct 14, 2014 3:37 pm
blue estate wrote:FOOKED :(
this one is repairable your aint mate :(
karl
Tranny Lover!!!
Postby blue estate » Tue Oct 14, 2014 3:44 pm
That's lucky for Rumble :D
Even if mine was the insurance renewal would have killed me :(
blue estate
Postby bigjohnthomas » Tue Oct 14, 2014 3:45 pm
Pissednbroke :wink:
bigjohnthomas
Postby karl » Tue Oct 14, 2014 3:48 pm
bigjohnthomas wrote:Pissednbroke :wink:
it has a hole init as well inside of the bowl
karl
Tranny Lover!!!
Postby karl » Tue Oct 14, 2014 5:39 pm
after speaking to rumble we going to get the injectors tested just to be sure it wasn't the injector that caused this even thow they were brand new :( but we need to be sure off everything as their will be new pistons a little ends going in as well :D
karl
Tranny Lover!!!
Postby bigjohnthomas » Tue Oct 14, 2014 5:44 pm
But what does it all mean Karl?
Why has it done it :?
bigjohnthomas
Postby ake » Tue Oct 14, 2014 5:51 pm
The damage was probably done before the injectors were replaced :(
Postby karl » Tue Oct 14, 2014 5:54 pm
ake wrote:The damage was probably done before the injectors were replaced :(
NO this van was running great i drove the beast quick on the pedal fast as fook before and after i replaced the clutch for a luk one
karl
Tranny Lover!!!
Postby Rumble bee » Tue Oct 14, 2014 8:28 pm
:shock:
I only asked Karl to do an oil change :lol:
Rumble bee
Postby karl » Tue Oct 14, 2014 8:38 pm
Rumble bee wrote::shock:
your oil did look dirty and black :D
karl
Tranny Lover!!!
Postby loot » Tue Oct 14, 2014 8:59 pm
Looks nasty, sure it'll be up and running soon enough.
Always seems to be the 2.2 engines, don't often hear of 2.4 engines doing it, well not on here anyway.
Ids map here
loot
Postby darkbluevanman » Tue Oct 14, 2014 9:03 pm
Has it been chipped?... hole would suggest lean or bad timing if it were petrol... not sure about diesel?
darkbluevanman
Return to Transit Talk
