Heater
Heater
Postby sc_BK » Sun Nov 11, 2007 11:15 pm
Thinking about a 2nd battery, and wiring in with a simple battery isolater switch. Then getting something like a 60w 1ft tube heater (240v), which should last the whole night on the 2nd batt.
You reckon a wee tube heater would be enough to keep the chill off the van overnight?
sc_BK
Re: Heater
Postby AndyG » Mon Nov 12, 2007 1:37 am
It'll certainly be quieter than a fan assisted version :!:
Have you got one to try :?:
Re: Heater
Postby sc_BK » Tue Nov 13, 2007 6:55 pm
Ordered one now, will just have to see what it's like when it gets here
Now just need to find the cheapest place for a 2nd batt!
sc_BK
Re: Heater
Postby captain hook » Tue Nov 13, 2007 9:35 pm
How does a 240v heater work on 12v?
A 12v 60w bulb will give out nearly the same heat!
Not enough to notice I would think.
captain hook
Re: Heater
Postby transitgeoff » Tue Nov 13, 2007 9:58 pm
batteries have gone up in price because lead has, blame the chinese i spose
transitgeoff
Re: Heater
Postby sc_BK » Fri Nov 16, 2007 10:14 pm
Got the heater t'other day, gotta say it does get pretty hot I reckon it should keep the cold off the van. Cheapest battery I could find was £38+VAT from a local motor factors, ford wanted £90+! :lol:
Also I asked the parts man at fords about the 2nd battery fixing kit, he had no idea what I was on about and didn't even believe me that the mk6 battery isn't under the bonnet :lol:
So I think I'll just make up something outta some scrap to hold it in place
sc_BK
Re: Heater
Postby motorwise » Fri Nov 16, 2007 10:32 pm
sc_BK wrote:Got the heater t'other day, gotta say it does get pretty hot I reckon it should keep the cold off the van. Cheapest battery I could find was £38+VAT from a local motor factors, ford wanted £90+! :lol:
Also I asked the parts man at fords about the 2nd battery fixing kit, he had no idea what I was on about and didn't even believe me that the mk6 battery isn't under the bonnet :lol: So I think I'll just make up something outta some scrap to hold it in place
sometimes I despair :(
http://www.motorwise.net
motorwise
Re: Heater
Postby motorwise » Fri Nov 16, 2007 10:33 pm
transitgeoff wrote:batteries have gone up in price because lead has, blame the chinese i spose
so I found out today when I stocked up :(
motorwise
Re: Heater
Postby Nighthawk » Fri Nov 16, 2007 11:57 pm
There IS a tsb from around 2003 time that details the fitment of the 2nd battery
it has all the finis numbers for the cables, clamps and vents, but it doesn't include a split charge or isolator in the circuit.
Transit.........Job done
Nighthawk
Re: Heater
Postby sc_BK » Sat Nov 17, 2007 12:17 am
Aye still got some 25mm cable left and bought a rally style cut off switch. The plan is to wire the inverter through the 2nd batt, leave the switch on most of the time, then when I'm parked up overnight flick it over to keep the main batt full.
Forgot to buy clamps to go on the battery posts though :oops:
Also, is there an easy way to remove the drivers seat so I can access the seat box easily?
sc_BK
Re: Heater
Postby madmark » Sat Nov 17, 2007 3:12 pm
sc bk if you are going to fit a second battery can we have some photo,s i for one would like to see them :wink: :wink:
Re: Heater
Postby davemfox » Sat Nov 17, 2007 3:15 pm
madmark wrote:sc bk if you are going to fit a second battery can we have some photo,s i for one would like to see them :wink: :wink:
Me too :D
Dave
2019 Transit Custom - DCIV, 170BHP, L2
1993 YZF 750SP
davemfox
Re: Heater
Postby sc_BK » Sat Nov 17, 2007 3:17 pm
and me :oops: :lol:
sc_BK
Re: Heater
Postby motorwise » Sat Nov 17, 2007 5:07 pm
there's two in mine - you can get them in without removing the seat easily enough :D
motorwise
Re: Heater
Postby Nighthawk » Sat Nov 17, 2007 7:23 pm
The seat tracks will unbolt off the base and allow you to look straight down on the battery location.
When you fit the second battery, make sure you fit a vent to it so the gasses produced when charging are allowed to exit the vehicle. They are flammable!
Nighthawk
Return to Transit Talk
