MinorMatt wrote:How would it fit on drums and discs, but not on the wheels???
LSi wrote:Altransit wrote:LSi wrote: Something of around 2600kg GVW on the van would be more than adequate, leaving me 2600KG MAM for the trailer, which would work out about right for what I need.
The trouble is that the smaller capacity vans also have a smaller GTW, for example mine is 2850GVW and only 3500GTW![]()
I was always told that you couldn't tow anything heavier than the tow vehicle, and this would seem to be correct from what you've just found out
I fear that the towing limit for the van is locked at 2t, as the GTW seems to follow the GVW for a limit of 2t.
As I have been informed on another site where I asked, If I approach VOSA and ask for the van to be downplated in order to sling more weight on the back, they will reject on the grounds that the 2000kg towing limit will be increased beyong manufacturer's specifications
Regarding the query about weight ratios, and the trailer MAM not being more than the unladen weight of the towing vehicle, this is correct for standard license holders, but the restriction is removed for B+E license holders.
merseycool wrote:Hello mate you also need to be aware of the operator licence requirements, somebody mentioned when moving goods on a vehicle or trailer you need a tacho because its for hire and reward purposes. Yoy need a tacho when the vehicles carrying weight exceeds 3500kgs if the goods being carried are fro hire and reward then you require a standard national operators licence, if the goods being carried are your own then you require a restricted national licence, to obtain the licences you will require a CPC certificate (Certificate of profesional competance) hope this helps, if you need any more info please get in touch through the forum thans Steve(doing
vannut wrote:merseycool wrote:Hello mate you also need to be aware of the operator licence requirements, somebody mentioned when moving goods on a vehicle or trailer you need a tacho because its for hire and reward purposes. Yoy need a tacho when the vehicles carrying weight exceeds 3500kgs if the goods being carried are fro hire and reward then you require a standard national operators licence, if the goods being carried are your own then you require a restricted national licence, to obtain the licences you will require a CPC certificate (Certificate of profesional competance) hope this helps, if you need any more info please get in touch through the forum thans Steve(doing
Operator's licence doesn't apply if your trailer is less than 1020kg Unladen weight so you'd be unlikely to ever need an operator's licence for a transit.
whitevanman66 wrote:this is all too confusing for me adding,subtracting ...all i wanna know is ive got a caravan chassis decked out with ply (bed size about 14.5ft x 5ftish) if i put a small car of my own(gordini turbo or mk2 golf) do i :
A need any type of operaters licence
B am i overweight (i know i am im on about the van)
i have a swb mk5 transit 80
if i need any type of licence where do i start to enquire & roughly how much......i passed my test in 89 if that makes any difference as to what would be on my license
