Andyg wrote:I've still got the original Slick 50 from about 20 years ago
But with all the, so called scare 'myths' going round, I never used it
And in those days, it was a hell of alot of money (for me anyway
Do you think it can 'go off'
And do you recommend a filter change straight after
or just add and forget
It is basically a PTFE addiditive in an amount of oil. PTFE is the most slippery substance known to man - technically less coefficient of friction than ice!
Whilst the oil may go off a little (but I doubt it) the PTFE additive certainly will not.
It was advised to be added to new oil, with a change of filter. I certainly would not change the filter after cos any of the polymer caught in the dirty filter would be lost if changed after. They do advise to run the engine for as long as possible after adding to "work it in" I would say this is best too, or at least 50mile or so if you can.
If the oil has gone off a little I would not worry as it is only about half a ltr if I remember and the oil is only a carrier for the ptfe polymer which is only about 10% concentrate if I remeber - If you write the label description for me I may be able to understand it as I am a polymer/plastic engineer by trade.
If you do put it in, what harm could it do? its only half ltr of ineffective oil afterall?
Originally they did do a test which involved running an engine whilst draining the oil and it did run for about 20mins at high revs if I remember? no other engine would do this??? this was the slick 50 however, I don't know about the others?
I personally use "molyslip" nowadays as its cheap on ebay and contains only molydium disulphide (bad spelling) and this is a well know and proven polymer additive for friction reduction, I sell plastic with it in conatining proven test data in labs. The only question is if the moly actually sticks to anything? but knowing the chemical make up makes me believe it will at prolonged engine temperatures.
Again though peeps - don't post conflicts etc as I am not interested in pro's and con's on the subject of additives - again, been there done that - now not interested, it works for me (if only in my mind).
Cheers,
Steve
