intransit89 wrote:captain hook wrote:Is that a bad thing
here we go again
ignore the fuddys of the forum
here we go again
bigmastif wrote:intransit89 wrote:captain hook wrote:Is that a bad thing
here we go again
ignore the fuddys of the forum![]()
but the welding bit is a idea young un
Guy88 wrote:1 tip
get a fire extinguisher![]()
and melting underseal is f*****g hot when it drips on you
intransit89 wrote:Guy88 wrote:1 tip
That’s 2 tips.![]()
I will grind the underseal of where I do some welding![]()
I got a fire extinguisher it sprays like white powder out
As I once had to use it when I testing some gas pipes out in daves van i.e. use a fag lighter and see where the pipes are leaking
MrMPuk wrote:intransit89 wrote:Guy88 wrote:1 tip
That’s 2 tips.![]()
The extinguisher will be no good now, so you need to get another one!
Guy88 wrote:http://uk.youtube.com/watch?v=ijnFRjKXPRE
Int are you german
Int are you german
slow transit wrote:Guy88 wrote:http://uk.youtube.com/watch?v=ijnFRjKXPRE
Int are you german
Guy
you shouldn't let him see that![]()
should be ok tho as mablethorpe nor skegness has a peir now
