Bobbyg wrote:d. try and "hide" the parrot box somewhere and then route the microphone either onto middle of dash or round the dash depending on length?
e. assuming I get the CK3000, where do you recommend fitting the answer / hangup control switch? On the 2 blank switches just above the gearstick?
Bobbyg wrote:However, when I switch the ignition off, the display disappears instantly. The manual says it should say "Goodbye" and if it doesn't, I need to reverse the two fuse holders. Did anyone else have to do this?
Bobbyg wrote:Is it just a case of start dismantling and see where I can hide them?
Bobbyg wrote:OK will try that though on first sight there doesn't appear to be much space behind th stereo for this spaghetti junction of wires! Whre did you put the actual blue parrot box thing? Behind the stereo as well?
