Retired boy racer wrote:sorry but you did ask.
Retired boy racer wrote:There' no fooling you fred when I get in my van she takes me to any where I wanna go. with in reason of course . just had the warp drive removed for its annual overhaul. its looking pretty good.
Retired boy racer wrote:As if I would lie to you Fred I dont think so.
baconsdozen wrote:Has any one ever had a gearbox or sump or even a back axle rust through from the inside?. Old engine oil mixed with a bit of detergent to make it sticky is a good cheap substitute for waxoyl to slow down rust.Note the slow it down comment,whatever you do you can't stop the steel in your chassis from going back to its natural state (ie) iron oxide
(rust) eventually.Bear in mind that if you leave one small bit un protected it will rust worse that if you do nothing at all so retreating every few months or so is a messy but worthwhile way of getting as much life as possible out of your old van.
