Twin exhaust
Postby Andrew-v4 » Wed Dec 28, 2005 12:56 am
looks good but i want them coming out the back 8)
Andrew-v4
Postby madmark » Wed Dec 28, 2005 2:38 am
neil you maybe write on that mate, if only i could find the svo exhaust downpipes then i can make the rest up! will probly go for a di style out the side after the rear wheel, like the original svo was! :?
Postby Gunslinger » Wed Dec 28, 2005 10:16 am
my bet is that the svo down pipes route both pipes (from v4 or v6) over to the drivers side of the vehicle until they get to the back to avoid the fuel tank, but even when you get to the back, you still have the spare wheel to contend with, much easier to just exit infront of the drivers side rear wheel
Gunslinger
Postby madmark » Wed Dec 28, 2005 12:46 pm
mate the problem is with the v6 fitted ,its the overdrive crossmember ,its in the way ,so you have to try and mod the downpipes to go round it, as the svo ones are shapped ,but useual ford they dont sell them anymore, and motorfactors never did! :(Image
Postby Gunslinger » Wed Dec 28, 2005 4:31 pm
two choices then ...
1) sweet talk your local metal fabricators into letting you use their bending equipment (i've seen exhausts done with a big manual machine like a plumbers bender before) .... this saves you the cost of their labour :) and build that section yourself
2) break out the grinder,hacksaw and welder and DIY it :P
Gunslinger
Re: Twin exhaust
Postby jonnyshag » Wed Dec 28, 2005 4:54 pm
Andrew-v8 wrote:Just wondering if there are anyone who has put a twin exhausts out the back of there van :?:
Fancy doing this but need a couple of pictures to get an idea.
is your van turbo , i had a citroen bx td with a staright though exhaust which sounded quite nice with the turbo and not like a mega loud boy racer car
jonnyshag
Postby madmark » Wed Dec 28, 2005 7:29 pm
:shock: no mate the mk1 is petrol v6, :)
Postby jonnyshag » Wed Dec 28, 2005 7:40 pm
v6 petrol nice :D thay wil sound cool
jonnyshag
Postby madmark » Wed Dec 28, 2005 7:45 pm
that true mate buts its keeping it original looking ,thats the problem, i have done so much work on it to get it looking original ,haveing a big exhaust wont look write! :?
exhausts
Postby MRspivvy » Wed Jan 04, 2006 7:46 am
I've got a set of twin side pipes like that custom mk1 to go on my mk2. serious fabrication required to plumb them in though.
MRspivvy
Return to Transit Talk
