unravel this one then.....
Re: unravel this one then.....
Postby executivetravel » Tue Sep 09, 2008 10:30 am
from ford parts...
thankyou
part number 4669224 £34.36 plus vat on order at moment shoul dbe avaliable tomorrow
thankyou
Andy
on the filter there should be a tdci decal or a di decal with a tick beside which filter the vehicle is if it is a tdci then use the filter number we supplied if not then then one you have fitted is correct , they will both fit just one has a finer filter inside
(obviously the finer filter is to protect the sensitive common rail pumps+injectors i suppose, probably clogs up faster though)
executivetravel
Postby executivetravel » Tue Sep 09, 2008 12:52 pm
on the fitted filter i can just see a X level with "Tdci" and a tick level with the "Di"
it feels better - i think they drained the filter, so ive ordered a proper part and that can go on it monday.
expensive tho innit...£35+vat
executivetravel
Postby Frag » Tue Sep 09, 2008 11:05 pm
Has the van any d.t.c`s,
Has it had a leak off test,90% of t.d.c.i faults are injectors in my experience,(you may have damaged these already with wrong filter,yep it would invalidate warranty)
The other 10% are egr valves :lol:
Check All vac pipes for being kinked over/rubbed thru,ones from turbo to soleniods nr airbox to egr valve then upto vac reservoir & servo pipe take off.
Seen t piece angled connector kinked flat at servo pipe,and connection to vac reservoir off or connected to a stud :o instead of pipe connection :lol:
Frag
Ford Technician
Postby executivetravel » Wed Sep 10, 2008 10:15 am
whats a DTC?
it can have a service (with a proper ford "TDCI" tick filter) then it can go to a different ford dealer if it feels the same
i doubt this one will have logged finding the wrong filter onto any system
its well overdue for a service anyway
executivetravel
Postby Frag » Wed Sep 10, 2008 10:47 am
executivetravel wrote:whats a DTC?
Diagnostic trouble codes,on a suitable reader.
There won`t be any code logged for the wrong filter,but permenanent damage may have been done to fuel system,mainly injectors due to fuel not being filtered finely enough (down to either 2 or 5 microns thru a TDCi filter).
Just as mentioned,if you go to a dealer they will refuse to repair any fuel system faults if they know about wrong filter,it will invalidate your warranty (and if this gets back to prior approval EVERY dealer will know)
Needs to got to main dealer,check for later pcm calibrations,check for dtc,carry out leak off tests etc etc
Frag
Ford Technician
Postby executivetravel » Wed Sep 10, 2008 11:19 am
worth the blag then, wont cost em anything to stick a laptop on it....
ill deny any knowledge
i bet they whooped when they saw that filter, and yet, it was put on by a ford ealer, wouldnt that be a great dodge, fit the wrong (but identical filter) next time round its invalidated the warranty!
scam!
executivetravel
Postby winterheating » Wed Sep 10, 2008 9:23 pm
are the pcm calibrations only requireed if its not at the correct idle speed or is there another calibration :?:
winterheating
Postby Frag » Thu Sep 11, 2008 12:01 am
Calibrations are updated all the time to address various running problems,depending on when your van was built,or the last time it saw a dealer there may be a full re-program/later level calibration available.
You won`t know without putting it on a machine,gonna have to be i.d.s or similar.
Idle speed etc cannot be altered or set,if its not right there is a problem somewhere that the engine management can`t rectify.
Frag
Ford Technician
Postby executivetravel » Thu Sep 11, 2008 10:52 am
humpf
the filter now leaks at the drain tap/bottom, the dealer drained it (without catching the derv in a jug) leaving the gbox end covered, should i complain? ive tried tightening it up, didnt stop it, not a flood and its in monday for a service (not at fords - £70 to fit a fuel filter?....go make love elsewhere geezer)
executivetravel
Postby executivetravel » Thu Sep 11, 2008 1:55 pm
its just gets better
when it went in i was told "do you want one fitted, it will cost £75" (plus vat)
i said...er no...
so i ordered one from parts tuesday (van was in monday remember)
this morning i had an email back....
good afternoon , yes the filter arrived we fitted this filter to your vehicle whist it was in our workshop , then we were asked to remove it , can you advise us any further
so i said...
i didnt order one till after my tourneo had been in to your service dept so they didnt fit the one i ordered. (unless they are physic, or using a tardis)
i was asked if i WANTED one fitting, (at a cost of £75 )+vat i assume)
rang another ford dealer near me....no stock, VOR tomorrow afternoon, 40p cheaper
4669224 is correct, not been asked for 1 yet
now then, if they havent used one yet, what have they been fitting, cos this dealer does loads of transits
are all those warranties invalid?
btw
4.537.951 has been superceeded by 4.630.200
executivetravel
Postby executivetravel » Thu Sep 11, 2008 2:47 pm
We had ordered one filter for a transit , for which it turns out was your vehicle , so when asked if we had stock. we had no spare stock at that time .
so I have got a slighty used one , would you like me to order a replacement one so that you have a fresh filter.
executivetravel
Postby FredTransit » Thu Sep 11, 2008 2:50 pm
:shock: WTF??? Are you telling me they were going to fit a 2nd hand filter (or have)??
FredTransit
Mk2 Trannyist
Postby executivetravel » Thu Sep 11, 2008 3:17 pm
no, silly boy
the claim to have ordered and fitted a £40 filter without knowing what any fault was, and removed it when i said i didnt want it
if you believe thatm click here
http://www.nessie.co.uk/
ill offer a fiver for the one thats been on 10 minutes
the important thing here is not my bus or its filter
its that FORD are fitting TDi filters into TDci vans+buses, what is the warranty worth after that?....zilch
executivetravel
Postby executivetravel » Thu Sep 11, 2008 4:06 pm
its not possible THEY fitted the tddi filter.........is it?.........
(no-one seems to keep it on the shelf)
wish id looked before
executivetravel
Postby MrMPuk » Thu Sep 11, 2008 4:15 pm
Funny you should say that, none of my local dealers hold the filter for the 125 TDCi either. Yet the Ford car dealer across the road holds 40 for the TDDi.
Return to Transit Talk
