Post up your Mk7 rust pics
Re: Post up your Mk7 rust pics
Postby pikeybob » Wed Mar 18, 2009 9:39 pm
Found some corrosion on the van :( :( Not on the body its on the Ford badge on the back door :? :? I get a pic up
The only mk7 still with ORIGINAL egr valve!!!!!!
pikeybob
Postby pikeybob » Sat Mar 21, 2009 11:00 am
Here we are
Then on closer inspection found this under both rear arches :( :( :(
pikeybob
Postby ake » Sat Mar 21, 2009 11:10 am
Oh dear :(
Postby pikeybob » Sat Mar 21, 2009 11:18 am
Always kept the arches clean & free from mud too. Why do i bother?
pikeybob
Postby ake » Sat Mar 21, 2009 11:21 am
Are you goin to try for a claim :?:
Postby pikeybob » Sat Mar 21, 2009 11:38 am
Is it worth it? There usless at Lincoln Ford. Put some underseal on it instead me thinks :roll:
pikeybob
Postby sportacus » Tue Mar 24, 2009 1:09 pm
shows why it pays to have a transit waxoyled as soon as you get it :D
115T280 sea grey limited
iv'e now killed 2 mk7 engines and a mk6, is that a record ?
sportacus
Postby pikeybob » Thu Mar 26, 2009 6:12 pm
Shouldnt need to in this day & age :x
pikeybob
Postby madmark » Thu Mar 26, 2009 6:19 pm
just use plenty of spray oil ,this will stop it!
i use oil sray , inoticed my tank straps the otherday were getting rusty :shock: so i sprayed them with oil as well! :wink:
Postby pikeybob » Thu Mar 26, 2009 6:21 pm
Worth a try, thanx 4 the tip mark :D
pikeybob
Postby madmark » Thu Mar 26, 2009 6:24 pm
mate i will allways use oil all over the van , i have allso drilled out the front arches ans filled them in oil ,this was a tip from transigeoff and the idea is to get the oil in the front arches before they go like lostpauls :shock: :shock:
i think i will be keeping the van for a wile so i dont want rust! :roll: :roll:
Return to Transit Talk
