EX RAC VAN OWNERS
Re: EX RAC VAN OWNERS
Postby Darren.w » Fri Mar 11, 2016 3:53 am
Hi.
My van has a dual mass. My van had done 110k I'm sure drove fine until one Saturday morning I started it and the dual mass was rattling badly so took it into work and replaced it with a luk dual mass flywheel, clutch and slave cylinder. The flywheel has twisted so had to cut it to get to the bolt heads. The lot cost me £300 + vat but my work paid the vat so I wash apply
Darren.w
Postby wronghole » Fri Mar 11, 2016 7:20 am
Indeed it would be false economy not to replace the dmf when replacing the clutch . If it was a smf you'd be changing just the clutch. :)
wronghole
Postby wronghole » Fri Mar 11, 2016 5:38 pm
don,t know if video file down loads on here.
Fitted roll up windows today. Fed up of leaving em open. wet seat and all that :mrgreen: :mrgreen:
wronghole
Postby t2myd » Fri Mar 11, 2016 8:32 pm
My mate selling a ex rac van needs a oil cooler and dint in wing Starts and drives , been used as a farriers van £1400
Transit vantastic !!!!!!
t2myd
Postby martynx » Sat Mar 12, 2016 12:19 am
Video views Ok...good job done :)
martynx
Postby wronghole » Sat Mar 12, 2016 8:29 pm
martynx wrote:Video views Ok...good job done :)
Thanks mate. Thanks for all your help :D
wronghole
Postby markspark71 » Sun Mar 13, 2016 12:09 am
wronghole wrote:Image
So how did you do it ?? :D
markspark71
Postby markspark71 » Sun Mar 13, 2016 12:13 am
mk2xr2 wrote:Hi All.
My 2008 Ex RAC van is feeling like it's due a new clutch ( currently @ 160,000 miles). In the Lex Autolease paperwork it had the clutch and flywheel replaced at 67601 miles. I've been searching the forum trying to find out which flywheel these RAC vans were fitted with from the factory, without much luck. I popped into my local Ford dealer today, to hopefully get the answer there. He looked it up on his parts system and told me it would be a dual mass flywheel setup. Is this correct or were they fitted with the SMF as they were a special build order for the RAC.
He did say they do a conversion kit for the van to run the SMF and gave me all the relevant finis numbers.
So has anyone got the definite answer?
Rob.
If your going for a solid conversion this mite help save a few £££ (not my item)http://www.ebay.co.uk/itm/321971289397? ... EBIDX%3AIT
Also if your doing the clutch and flywheel its a very good idea to do the rear crank seal while your in there
markspark71
Postby wronghole » Sun Mar 13, 2016 4:35 pm
Mark have a look at Auto window wind up on here mate. Straightforward but not easy :roll:
wronghole
Postby mk2xr2 » Tue Mar 15, 2016 11:08 am
Rob.
If your going for a solid conversion this mite help save a few £££ (not my item) <span class="skimlinks-unlinked">http://www.ebay.co.uk/itm/321971289397?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT</span>
Thanks for the link. Part numbers and finis code are different to what I was given the other day at my Local Ford dealer. But I can pop in today and ask them to check those numbers for me.
I have been on Eurocarparts website and they do a Transmeck solid flywheel conversion kit (product code 633590111) for £214.99. Says it includes everything, so for the money seems good. Anyone used this kit or any parts by Transmeck as I have never heard of them :?
mk2xr2
Postby wronghole » Tue Mar 15, 2016 3:36 pm
Having fitted smf last year l have not had any problems, infact l prefer it to dmf. However at the time l was warned off Transmeck because they judder and have issues with longevity (allegedly) .
Although they cost a bit more l used lUK. :D
wronghole
Postby mk2xr2 » Tue Mar 15, 2016 5:29 pm
Trouble I'm having is finding someone who does a LUK SMF conversion kit. All the kits I do find are makes I have never heard off.
Can anyone tell me a company they have purchased a genuine LUK kit from.
mk2xr2
Postby wronghole » Tue Mar 15, 2016 10:27 pm
mk2xr2 wrote:Trouble I'm having is finding someone who does a LUK SMF conversion kit. All the kits I do find are makes I have never heard off.
Valeo do a good reliable conversion kit. That'll work mate :D
wronghole
Postby t2myd » Tue Mar 15, 2016 10:50 pm
My mates got a couple of 3.58 axels if any good To any of you lads £260'
t2myd
Postby markspark71 » Fri May 13, 2016 5:39 pm
Hi guys just a quick one what size tyres are fitted to the ex rac
markspark71
Return to Transit Talk
