MinorMatt wrote:isnt the maximum towing capacity for the lower rated vans (260/280/300) 1500kg MAX (so long as its within train weight)? It certainly is for the earlier 80/100/120s.
From the number above I doubt it's even that much.
froogle wrote:Hi
Sorry to reserect an old thread....
I have read through the post and am still a little confused as to what I can tow.
I have a fwd transit and the plate on the inside of the passenger's side door reads:
2455 = that is the max weight the van can be when loaded
3500 = that is the maximum weight the van and trailer can be when added together
1350 = the max weight for the front axle
1360 = the max weight of the rear axle
The last two 1350+1360 will always add up to more than the first 2455 to allow flexibility on placing the load
I passed my test in 1996. What is the maximum weight I can tow? I am looking at a trailer, I don't know what it weighs yet as I've not bought it. I am looking to tow a car (for personal, not business use)
On another note the trailer I am looking at has no plates on it to say what it weighs or will carry. Do I need to have a plate on it? It is a full size trailer designed for transporting cars.
froogle wrote:My van is never full. It is totally empty bar myself driving.
(ROG) wrote:froogle wrote:Hi
You have B+E licence so those are the towing rules we go by in your case
Maximum plated weight or tyre load rate for the trailer is 3.5 tonnes
The total weight of the van and trailer added together must not exceed 3500
Now what the trailer weight can actually be will depend on what the van weight actually is when it is towing it - if your van actually weighs 2000 then your trailer can weigh 1500
If your van actually weighs 1500 then LEGALLY you could tow a trailer weighing 2000 BUT that would not be SAFE as you would likely get the 'tail wagging the dog' effect
froogle wrote:(ROG) wrote:froogle wrote:Hi
Thanks that's clears it up. The van is always empty, I only bought it to put my quad inside to take it off road. I think the weight is about 1550kg on an empty van isn't it? (MY2000 MK6) That would leave me 1950kg before I went over the train weight. I normal car probably weighs 1000kg? and the trailer is probably about 600/700kg. So I should be ok towing?
Ideally I would need to get the van on a weigh bridge to get the weight. Also as trailer is not platted so would I need to get a place on it?
thanks
Remember the trailer and load should ideally weigh less than the towing vehicle
ginsambo wrote:ROG do the restricted operators licenses apply if you are training over 3.5T? I am told they do. Whilst a 1020kg or under trailer is discounted in your train weight, and whilst you may be under 3.5T in a van, in a chassis cab tipper you are definately over it unladen pulling a 1.6T digger, even with with trailor (1020kg) deducted. Can VOSA do you for being over 3.5T train weight (excluding 1020kg trailor) without a restricted use license? My understanding is that, they can. Or is the minidigger discounted because its on the 1020kg trailer?
g98churchm wrote:So, just wondering...
i've got a T350, i use it for personal use not business and, i'm looking at getting a towbar and 750kg boxtrailer.
where do i stand, do i need the b+e licence and a tacho??
