Whats your MPG ?????
Re: Whats your MPG ?????
Postby MrMPuk » Fri Nov 21, 2008 10:34 pm
Guys, you need to read the post on the first page. You need to give more info about the vans otherwise the info you are giving is worthless!
Postby winterheating » Fri Nov 21, 2008 11:04 pm
vandaft1980 wrote:T350 135 55 plate!!!!!!!!! its only done 24300 miles .16 mpg is what i worked it out as too . its 3 years old next month so will be getting its third service then .it does a slight misfire when idling also does this about 2000rpm when driving but only sometimes .ford just can not find the fault ,i thought maybe ingitor problem but i'm a spark so not really sure.anyone any ideas.cheers
rough idle, its a good chance one of your injectors is dumping more fuel than it should :!: i'd defo try an other garage or diesel specialist.
winterheating
Postby executivetravel » Fri Nov 21, 2008 11:54 pm
still under warranty then
take it to fords with a record of its fuel consumption, tell them 16mpg simply is not acceptable
as already said, chances are its an injector, but a diagnostic may not show that up, it would need all 4 removed and sent for a test - your fords will not have the reqd equipment
ive had 37mpg out of my swb 2.0 tdci 125 glx tourneo
executivetravel
Postby pikeybob » Sat Nov 22, 2008 5:01 pm
Oh sorry chaps shouldnt rely on the trip computer :oops: worked it out properly this time.
I get 34mpg
Its a mk7 2years old 17k on the clock 85ps/T260 swb low roof with around 250 - 300kgs in the back (yes i travel light) on combined driving. Hope this is better :wink:
The only mk7 still with ORIGINAL egr valve!!!!!!
pikeybob
Postby Hydraulic Bloke » Sun Nov 23, 2008 11:59 am
executivetravel wrote:
Hydraulic Bloke wrote:Nope sorry we have 4.5 lts to the gall here, Wikip is yet wrong again
you better tell this guy then...
1 gallon=3.785 litres
http://www.rustbullet.com.au/epages/whi ... ts/4000142
Made in USA on can
You can go as fast as you want on a push bike
Hydraulic Bloke
Postby executivetravel » Sun Nov 23, 2008 12:31 pm
Made in USA on can
i asked the seller, he wasnt aware of the markings! (been on the XXXX i reckon)
executivetravel
Postby pikeybob » Mon Nov 24, 2008 8:50 pm
Think im carrying more than said. But i cant really be arsed to weigh everything :lol: :lol: Its half full anyway
pikeybob
Postby executivetravel » Mon Dec 08, 2008 10:25 pm
500 miles on 54.08 ltrs
42mpg
125ps tourneo tdci (old smokey)
avg 2-5 passengers but has full compliment of seating
executivetravel
Postby Jaffa » Thu Dec 11, 2008 10:23 pm
45mpg, down to 35 doing a good tow.
Old shape Ex RAC 115ps, Miss Daisy driving.
Jaffa
Postby MrMPuk » Fri Dec 12, 2008 3:11 pm
Jaffa wrote:45mpg, down to 35 doing a good tow.
You sure it's not 85ps?
Postby executivetravel » Sun Dec 21, 2008 9:03 pm
480 miles
63.79ltr
34mpg
tourneo tdci 125
executivetravel
Postby transexl » Mon Dec 22, 2008 7:59 pm
...HAVE TO GET THE CALCULATOR FOR THIS !!!!!!
WHEN, OH WHEN WILL THE UK REALIZE THAT THE METRIC SYSTEM - !!!!!
oh no, enough of that !!! :wink: ...
Right, only today I topped off after doing 505 Kilometers - that´s 313 miles - and it took 38,5 litres in - that´s
7,6 litres for 100 km ! :lol:
OK, GETTING THE CONVERSION FACTORS AS WELL !!!! :roll: :
I think that´s 8.5 gallons (imp. gallons? I read the above discussion afterwards, but did not get what is right - took the 4,5 litres to convert... ) for 313 miles -
that is thirtysixpointeight miles per gallon ??? :?:
This was my everyday-24-mile-a-trip-commute and other stuff mainly on the "Autobahn", (...being a major obstacle doing about 55 to 60 mph...) or b-roads ("Landstrasse")... .
Had more with motorbike loaded and more speed - but had less as well !!!!!!
After topping off I did the "PowerUp/EGR-mod" following MarkM (One turn - WHAT A SUCCESS !) - so what mpg will it be in the future :| ?
For Tranny details - see below !
stefan
...heinkel statt harley...!
..."TEUTONISCHE-1998-F100-2.5-normallyaspirated-76PS-"banana"-flamestart-diesel-3.89trans-4.11diff-semihighroof-shortwheelbase-twinbackdoors-whitewithblueGT40stripes-"bit"ofrust-mopedtransporting-NOEXTRAS(exeptfortheABS)-205450km-doingsomemaintenanceupdatingandrepairsmyself-fearingbodywork-promptstarting(...)-SMILEY-POWERUPbyMarkM-TRANSE"...
transexl
Location: Mönchengladbach, Germany - near Dutch border luckily....
Postby MrMPuk » Mon Dec 22, 2008 8:11 pm
37 mpg isn't bad.
Postby transexl » Mon Dec 22, 2008 9:49 pm
...think so, too !
(If my conversing is right, though).
I´m happy with the verified "7 - 8 litre per 100 km".
Few people over here - even car-nuts - believe me at first when I tell them...
UPDATE on Dec. 28th :
I did 420 km/260 miles since "power-up".
Usual driving habits, but took the Tranny to full speed just to see what happened there (It DOES go to full speed more easily, by the way !) about four times.
It took 27,39 l or 6,08 imp gal which results to 6,6 l/100 km or
42,7 mpg - right ?????
I double-checked all possible faults - can think of none !!
Considering that only now I found that I can change gear SO much earlier, but drove it like I used to on those 260 ms... - maybe there is even more mpg to be won ?
transexl
Postby addbrad » Sun Jan 25, 2009 8:36 pm
2005 2.4 115 T350 MWB High Roof, 118k on clock.
Did 167 miles today with foot flat down most of the way (70/80) but with only a light load, left with a full tank and cost me £40 when i got back.
167 miles 9.99 pence per litre i make that 18.98mpg :(
addbrad
Return to Transit Talk
