eco den wrote:finished forensics on it, not holding much hope they'll get anyone...
went to see what was in the back, they left me a few basics, and some screws.
no sign of any damage at all. they removed cover under the steering column, but all wiring intact. some kind of terminal or laptop port under there, and found out they had trouble recovering it as the steering lock is on! this means they either just lifted the van, or drove it by releasing the steering lock, which I assume can only be done with a key.....
this is becoming more of a mystery. how the hell have they done it??? Is there a ford master key? or have they managed to aquire a duplicate of my key?
think I'll get some deadlocks and a steering lock.
judder wrote:I want to disable the door lock - How do I remove the door card ? - I see 5 screws - is that all ? thanks.
Gavin wrote:Only 8 wires? Cool. I will be cuttingmine out and blackwireing it elsewhere under the dash into another type of connector and then make up a loose lead (which i will keep in the house ) with the counterpart connector to an obd socket. Unfortunately all you can do is slow then down to the point where they give up and try someone elses van. I reckon with the tibbe key and that tool you could be in and away in under three minutes...
