Neds Turbo (discussion topic)
Re: Neds Turbo (discussion topic)
Postby andz327 » Mon Mar 30, 2020 3:22 am
Make sure this bits mint, clean , free moving and no broken bits and make sure oil feed pipe is clear, if there's a gauze in either end of pipe/banjo bolts throw it to fook
Can get you full van with good engine
Swb semi roof silver 06 rusty cheapImage
Sent from my SM-G975F using Tapatalk
andz327
Postby ned » Mon Mar 30, 2020 4:09 am
How cheap is cheap Mr Andz sir?
Aye that bit will be coming off once I get some more brake cleaner :P the biggest problem I have is finding where to get the manifold bolts from, one is weird, it's like a normal bolts with another threaded part on top for the egr cooler to bolt to :?
Going to check the pick up pipe, drop the oil and do a service on the van when I've put everything back together
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby ned » Thu Apr 02, 2020 3:36 pm
Got a turbo cartridge coming from Niva trading tomorrow, an oil filter coming from Tpuk, oil and coolant coming from lubriage carparts and some rtv oil sump sealant 8) Lucifer will hopefully be alive again soon :D excited as it gives me something to do :P
ned
Return to Transit Talk
