2.5 DI MPG - What does yours do?
Postby joelataxi » Fri Feb 03, 2006 9:52 am
Dover to home = 300 miles, just do it on a tank full ................
at average 85mph tho
edit is.... forgot to say 2.5 td
joelataxi
Postby MarkM » Mon Feb 27, 2006 11:46 pm
I am now getting around 400+ a little to the tank but then I have had a fiddle with the fueling...actually turned it up, but I have removed the EGR from the circuit and this is the result, not a particularly heavy foot and on A roads mainly with the speed averaging 60-65mph. Probably half loaded weight wise. 2.5DI 70ps SWB
Got scared last night though....low fuel light came on (it had done this before but at a higher amount of fuel registering) anyhow I had to keep going...backed off the speed a little and it was starting to get scary as slight hills up and down were playing havoc with the needle but on the flat it was fumes being indicated. I had some horrible thoughts about the AA and bleeding the system, got to the petrol station and 63 litres of Diesel later I am happy but what is now very scary is I had just 5 litres of fuel left! I doubt that would have got me very far. So I now also have a question, what is the amount of fuel left in tank supposed to be when the low fuel light comes on?
MarkM
Postby daddy cool » Tue Feb 28, 2006 10:19 am
Have a read of this...
http://www.fordtransit.org/forum/viewtopic.php?t=2563
Hope that helps :)
Even if you don't need it, grab it.
The minute you do need it, it'll be gone.
daddy cool
Postby MrMPuk » Tue Feb 28, 2006 10:23 am
daddy cool wrote:Have a read of this...
Hope that helps :)
That's on the 2000 onwards van and this post is about the pre 2000 2.5Di engine.
Postby daddy cool » Tue Feb 28, 2006 11:24 am
Oops my bad!
Leave it to the experts :oops:
daddy cool
Postby oldsaltoz » Sun Mar 05, 2006 2:07 pm
Refurbished my Epic injector pump (Leaking seals) filled up and did 425 Km still had a bit over a quarter tank left.
68 Lt capacity I think, divide that by 4 and multiply by 3 I get around 37 Km per gallon or 8.33 Km per Litre.
Avagoodweekend......
1998 Mk 5 Smiley, 2.5 diesel turbo, LWB Mid roof. Mobile tool box and storage.
oldsaltoz
Postby madmark » Sun Mar 05, 2006 6:46 pm
mine is around 320mpg to a tank ! at 60mph :?
Postby rallyevo3 » Mon Mar 06, 2006 11:21 am
320mpg !!!!!! is it for sale :lol:
rallyevo3
Postby Luke » Mon Mar 06, 2006 8:31 pm
this is how i work out MPG
1) fill van tank full
2) reset trip meter
3) drive around untill van needs filling again
4) fill van and get recipt
5) on the recipt will be the litres you have put in multiply the litres by 0.22 this will give you the gallons, then write that number down, look at the trip meter and write that down.
6) divide the miles travelled by the gallons eg 400miles/12gallons=33.3mpg
this is the forumla
miles traveled = mpg
litres x 0.22
obviously its only as accurate as your speedo is but gives as acurate reading as you can get.
:D
Postby Smooth Hound » Fri Mar 31, 2006 3:08 pm
1994 Transit lwb high top 190, was doing 350 miles to tank but since adjusting fuel pump and wiring open air inlet butterfly Iam now getting about 425 miles to the tank, and its more powerful than it was.
Mike
Smooth Hound
Postby AndyG » Fri Mar 31, 2006 4:26 pm
Luke wrote:this is how i work out MPG
2) reset trip meter
this is the forumla
litres x 0.22
:D
Luke your a wizz 8) My own experience is you can't trust the forecourt pumps. The reason; I always run mine down to the minimum before filling up. Then I can tell where the crooks are. How? Well my tank is sometimes as big as 78 litres :shock: that's how :!: On my '96 SWB LOW 70ps fully loaded with ladders; min 350. The most ever (probably had more longer runs) 450 to the tank. 2000 SWB LOW 85ps Auto same load 325 to the tank the most ever 375to the tank. And if you wait for the scheduled oil change it plummets down to 280 :shock: to a tank. Hence oil changes are and always have been much much sooner on any of my vans :wink: :D I try and be light footed but it is very difficult at times however I do tend to stick to one rule that is; keep revs below 3000rpm. I find it helps alot. And any of you with no rev counter with a 'normal' SWB that's 70mph in 5th/overdrive. After this you can almost see the fuel guage moving- well if you look long enough :lol: you know what I mean.
Postby Ron » Fri Mar 31, 2006 7:29 pm
2) reset trip meter
this is the forumla
litres x 0.22
:D
Here's an alternative:
http://www.taxbuddies.com/mpg.php
Ron
Postby Luke » Fri Mar 31, 2006 7:33 pm
2) reset trip meter
this is the forumla
litres x 0.22
:D
thats ok but you still have to guess the miles you have done ont the fule you have put in - you may have gone on to the fuel that was in the tank if you get what i mean!!!
still handy as a rough guide!!! :D
Postby Hairylex » Fri Mar 31, 2006 11:01 pm
i run my 96/97 on bio now but on norm it does 400 to 440 on a full tank and the gague seems to keep pace with the loss and milage well.
she burns a little more on bio (380 to 400) but its only 68p a litre so frankly i dont care.
oh mine has a non(pre) banana engine so that may affect it.
ALEX
Why pay for electricity when you can get it for free?!?
http://www.elementalenergyservices.co.uk
Hairylex
Postby Luke » Wed May 17, 2006 5:21 pm
Right just filled up my swb mk4 Di (70ps) with 49.76 Litres - the gauge was still showing 1/2 full :roll: but i'd an idea that wasnt very accurate!!
anyway on that 49.76 litres having filled up full last time i knew i'd travelled 365 miles - or at least thats what the trip meter says.
49.76 x 0.220 is 10.9472 gallons
(miles/gallon) is 365/10.9472 = 33.34 MPG :shock: :D
not bad considering all of it was local short runs, some with a trailer on the back - but mostly the van was unloaded. the speedo may be inaccurate but if it was 10% out it would still be 30mpg- cant compain at that!!!! :D would be interesting to see what i could get on a run!!! :?
Return to Transit Talk
