Top Speed
Postby stevo » Mon Jul 03, 2006 8:56 pm
Our N reg SWB 80 does 85 on a good day. Its had the Bollocks ragged off it but it still goes.
Formely ibanez2005
Your's is the new Ford Transit!
2003 100 T260 TDDi swb
stevo
Postby EasternT280 » Sun Aug 06, 2006 1:27 pm
I have a SWB med-roof T280 with the 85ps 2.0. At the time I got it, I had a manual trans. Peugeot 406 V6, yet I was still highly impressed with the Transit, Ford seemed to do an excellent job making a commercial vehicle engine, an 85bhp engine should struggle with 1700-odd KG of van, but it does fine! According to the GPS, my clock is 4 mph out, at pretty much all speeds, which is damn accurate compared to a lot of stuff. It'll do 93mph on the level, which I was also highly satisfied with, and I've seen 98mph down a hill, not sure if it had any left, but seeing the needle at 104 for the first time in that thing sure was a thrill! :D
EasternT280
Postby harry1 » Sun Aug 06, 2006 1:52 pm
8) me 98 2.5di swb cruise 65/70. on way home from work will do 80 it dont like it but always seems faster in the early hours,better performance since exhaust replaced and been running it with acetone for a couple of months now ,and defo notice the difference when i dont put acetone in,oh small tip regarding squirting acetone into you tank,i have a 1 litre plastic bottle which i half fill with diesel ,i use a syringe to measure how many mills i need then squirt the acetone into plastic bottle then pour into tank,saves squirting 100%acetone straight onto plastic filler neck ,cant be good long term on the plastic, not to bad when its diluted to less than a mil to 1 litre of diesel thru your pump and fuel lines cheers H
harry1
Ton up
Postby Terry » Wed Aug 16, 2006 8:25 pm
Managed to squeeze an indicated ton out of her on the way back from
Keighly empty (had just filled up at a Texaco garage, seemed smoother & faster than Tesco's own !, but might be my imagination !) GPS showed 94.
Pallet Puller
Terry
Postby MrMPuk » Wed Aug 16, 2006 8:28 pm
Proper fuel will always be better than supermarkets. That's why supermarkets are cheaper!
Postby mr Grimly » Wed Aug 16, 2006 9:05 pm
My J-reg 2.5d 190 lwb semi-high top with wife,kids,dog,luggage and towing caravan will sit at 60/65mph untill you hit a silght gradiant then it's another story..... slows down a bit !
mr Grimly
Postby rover » Wed Aug 16, 2006 9:11 pm
I was down to about 65 coming up the M1 towards Leicester Forest East services on Sunday :( Didnt realise how steep it was :? Will still cruise happily around 75-80 on a flatish road, cant say for sure though cos my speedo UNDER reads badly, I followed Luke down to Billing and he says he had anywhere between 60 and 75 on the clock, I had 45-55 :shock: but we were passing all the lorries :D
Rover.
rover
Postby Guy88 » Wed Aug 16, 2006 9:12 pm
On ly way back from billing i had 102mph on GPS and still no where near the redline :shock:
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby MrMPuk » Wed Aug 16, 2006 9:16 pm
But your's is petrol, try that with a ton in the back!
Postby rover » Wed Aug 16, 2006 9:17 pm
I reckon your has the same diff as mine Guy :D 4.11:1 :D
Thats why I'm loathed to swap the back axle for a wider Mk4/5 one, I think I'll nip over to the back axle thread, need to know if I can swap my Mk3 diff into a Mk4/5 axle!
Rover.
rover
Postby Guy88 » Wed Aug 16, 2006 9:19 pm
Mine has diff code L 8)
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby rover » Wed Aug 16, 2006 9:25 pm
MrMPuk wrote:But your's is petrol, try that with a ton in the back!
I'm carrying at least half a ton at all times :( last winter after I had swapped the engine and box I took everything out including the compressor and cabinets and went for a run up the A52, felt like I was driving a bloody racing car :lol: :lol: :lol:
Rover.
rover
Postby Clayton » Thu Aug 17, 2006 12:42 am
Ive had more than 110 out of mine, so that makes mine the fastest diesel on this site so far.
TDCI WITH BLUEFIN
Clayton
Sportvan Owner!
Sportvan Owner!
Postby Clayton » Thu Aug 17, 2006 12:44 am
Mine does 110 up hill, and thats no joke.
Clay
Clayton
Sportvan Owner!
Sportvan Owner!
Postby MrMPuk » Thu Aug 17, 2006 12:53 am
Clayton wrote:Ive had more than 110 out of mine, so that makes mine the fastest diesel on this site so far.
TDCI WITH BLUEFIN
I think Nitroman might have something to say about that!
Return to Transit Talk
