veg oil
Postby excalibur » Thu Jun 28, 2007 7:28 pm
Well folks, as from 1st July, if you use less tha 2500 litres per year you no longer need to register or pay duty.....just keep simple records
http://www.hmrc.gov.uk/briefs/excise-duty/brief4307.htm
That now makes it worth doing, 20 litres from the cash and carry is £8.00
excalibur
Postby mickdee » Thu Jun 28, 2007 10:33 pm
Therefore 2500 litres = 549 Gallons
549 Gallons @ 30 Miles Per Gallon = 16,470 miles
Therefore that equates to 16,470 miles per year,of running on veggie :D :D :D
mickdee
Postby FredTransit » Tue Jul 03, 2007 3:58 pm
Result! Strange it wasn't more widley publicised.....
FredTransit
Mk2 Trannyist
Postby MrMPuk » Tue Jul 03, 2007 4:05 pm
This about the production of biodiesel, not using chip fat in your vehicle.
Postby licinius » Wed Jul 04, 2007 8:43 pm
Changed the fuel filter on my 2.5 banana engine today & straight away added 20 litres of pure veggie oil to a virtually empty tank & didn't notice the slightest bit of difference :D
Its a 97 Tranny with 135k on the clock so I'll change the fuel filter again in about 500 miles & see how I get on.
Exempt producers are also required to keep simple production records (date of production and quantity produced, in litres) on an ongoing basis, and retain these for six years.
Reads to me like its no longer illegal to use fuel without paying duty, provided that you don't use too much (no way i'll use 2,500 litres in a year).
licinius
Postby MrMPuk » Wed Jul 04, 2007 10:01 pm
licinius wrote:Exempt producers are also required to keep simple production records (date of production and quantity produced, in litres) on an ongoing basis, and retain these for six years.
That says nothing about using fuel, it says lots about producing it though!
Postby rossy » Thu Jul 05, 2007 7:30 pm
I have used veg oil in my 3.1 td Trooper for some time and now my Transit and think the engine is not as loud for sum reason.The only problem I have with running on this is the look the shop assistant gives you when you hit the check out with a trolly full o veg oil! :wink:
rossy
Postby FredTransit » Thu Jul 05, 2007 7:41 pm
rossy wrote:I have used veg oil in my 3.1 td Trooper for some time and now my Transit and think the engine is not as loud for sum reason.The only problem I have with running on this is the look the shop assistant gives you when you hit the check out with a trolly full o veg oil! :wink:
Get it from the wholesalers then, they should be used to buying it in bulk, and it should be cheaper.
FredTransit
Mk2 Trannyist
Postby FredTransit » Thu Jul 05, 2007 9:33 pm
MrMPuk wrote:This about the production of biodiesel, not using chip fat in your vehicle.
Actually I thought you were right until I saw this (posted by ashbyspannerman in the tech section)
http://www.dieselveg.com/
STOP PRESS *** Revised June 2007 Revenue & Customs biofuels simplification - Change in the way UK vegetable oil fuel duty is collected was passed in Parliament on 8th June 2007 and will come into effect on 30th June 2007. *** STOP PRESS
Earlier this year Revenue & Customs proposed:
A de minimis production level of 2,500 litres per annum below which producers would not need to enter premises, submit returns or pay duty (Please note: we seem to have many customers who are getting confused by Revenue & Customs use of the word "producers", we have checked and it has been confirmed that USERS and PRODUCERS can be treated, for these purposes as THE SAME),
FredTransit
Mk2 Trannyist
Postby licinius » Sat Jul 07, 2007 3:10 pm
Had a good blast in my transit today to see how it runs on SVO. Its a 2.5d banana engine with Bosch FIP & 165k on the clock. The previous owner admitted not looking after it & this was substantiated by an air filter that looked like it had been barbequed!
I've fitted a new air filter, new oil/filter & fuel filter & in keeping with my policy of in for a penny in for a pound, filled it with pure SVO (KTC from Makro) & went for a blast on the motorway.
The van pumps out a lot of white smoke on start up (which I expected) but soon ran clear(ish). The only problem occurs with foot to the floor acceleration which results in excessive white smoke (not very pleasent for those behind me). It sits nicely at 70 with no excess smoke, the problem is just with accelerating.
Is this likely to continue or is it possible that the engine is just clearing out all the cráp from years of neglect?
licinius
Postby MrMPuk » Sat Jul 07, 2007 3:18 pm
It will continue.
Postby FredTransit » Sat Jul 07, 2007 3:22 pm
Try mixing it 50/50 with diesel and reduce the diesel until the white smoke comes back, then take the mix up a bit, sounds like trial and error.
FredTransit
Mk2 Trannyist
Postby licinius » Sat Jul 07, 2007 3:40 pm
FredTransit wrote:Try mixing it 50/50 with diesel
:shock: Have you seen the price of diesel m8?? I'll try it the other way round starting 10% diesel & gradually adding a bit more if its doesn't clear :wink:
licinius
Postby FredTransit » Sat Jul 07, 2007 3:52 pm
:lol: Yeah i know! That could work too......
FredTransit
Mk2 Trannyist
Postby gemini » Sat Jul 07, 2007 4:27 pm
licinius wrote:Had a good blast in my transit today to see how it runs on SVO. Its a 2.5d banana engine with Bosch FIP & 165k on the clock. The previous owner admitted not looking after it & this was substantiated by an air filter that looked like it had been barbequed!
i wouldnt worry it'll be needing a pump soon
gemini
Return to Transit Talk
