by surfersexperiment » Sun Apr 27, 2008 1:33 am
Well the thread on the BIO certainly has moved on.
Sorry to all about ranting off in my last post.
Now back to topic, regards the BIO, as there seems at least 2 peeps on the thread that are going to try.
To those peeps, please be certain that your motor will take BIO, we are not talking straight veg oil from the supermarket here, we are talking processed veg oil, that comes out as BIO Diesel. It is as good as diesel in many motors, but not all. If you are going to try, research it first. Don't assume that BIO is the same as diesel if you are buying it from a forecourt. I say this because diesel is refined to a standard for the manufacturers engines (i.e all of them) whereas BIO is manufactured by independent processors and sell this to forecourts (all independent) or from their own premises. There is a BIO standard EN14214, but you will struggle to see it displayed.
If you are planning on going down the BIO route then you either purchase your BIO from a recommended source, i.e where trucks and coaches fill up, as you are pretty safe that if they are taking 500litres a time then you will be OK. I used a trusted source when I started out, he displays that EN cert as well, but it's all change in BIO, prob isn't even valid and the processors are working to a new one. Or, make your own! DIY and you know what you are putting in and getting out, there are lots of resources on the web to achieve this.
Personally my story is this. So far have completed nearly 3,000 miles using BIO with a 2.5 DI with a Bosch pump. In the early stages I ran 50/50 with diesel, then went down in the diesel percentage. In the last 3 weeks I have been 80/20. Last week I thought it warm enough to go straight 100 BIO. She ran fine to start, bit lumpy in the morning (4AM) apart from that great. Then on Thursday she lost power on the motorway at approx 4.30AM, kept going, although not a tad over 50. Pulled the fuel filter at work to have a look, nothing nasty really. Left work with new fuel filter, all normal (it was warm very warm though, for April). Spoke to my mate who runs a Mitubushi Warrior (03 plate) on the same stuff as me (and has done so for around 2,000 miles) and his filter was watered. He decided to drain his tank etc. This was a bad supply, we had both been to the same garage and the result, lazy processing, too much water.
I do see where MR Puk comes from. Diesel is Diesel, BIO is hit and miss. Although make your own and your good, as long as your motor can do it, be careful.
Me,for now, still on BIO, although this will be short lived as I am soon moving up to an 04 Tranny and I don't think BIO sits well with that! Although if anyone has seen or heard of a 03/04 tranny jumbo hi roof crew cab running LPG, let me know,otherwise, it's the diesel.
Mark
