john54321 wrote:Right i've found a 3.73 axle from a 2.4 mk7. However its from a 6 speed and mine is a 5 speed, is that a problem or is it still a straight swap?
wronghole wrote:john54321 wrote:Right i've found a 3.73 axle from a 2.4 mk7. However its from a 6 speed and mine is a 5 speed, is that a problem or is it still a straight swap?
Hi fella, should not be problem , 3.37 is 3.37 . I have one on mine , ratios are similar to a family saloon . Haven't done any towing but l have had a over a ton of cable in the back with no problems.
When you've done it you could take it to Vantuner for a bit of mapping magic
john54321 wrote:wronghole wrote:john54321 wrote:Right i've found a 3.73 axle from a 2.4 mk7. However its from a 6 speed and mine is a 5 speed, is that a problem or is it still a straight swap?
Cheers mate, i'll go and collect the axle in the next few days.
Any ideas what the cost should be for a mechanic to swap the axle?
john54321 wrote:Thanks guys, appreciate the advice!
wronghole - that paintwork look the nuts! inspired me to take a trip to halfords to pick up some Mer
wronghole wrote:john54321 wrote:Thanks guys, appreciate the advice!
Not mine mate . Markspark, s . Good init . Might get him to do mine though
