Tacho?
Tacho?
Postby mrgasoil » Fri Mar 02, 2007 10:11 pm
Looked at a couple of pick-up t350's today with electronic tacho's. :?:
If a vehicle has a tacho fitted do you have to use it :? :?:
Also the (electronic) part puts me off, i've used my mates erf ec10 95spec and i assume thats got a mechanical tacho? (it ticks). I know it may be a daft question but my exp with tach's is very limited :oops:
mk5 flareside with tail-lift GONE and will be missed!
Mk6 T350 LWB DRW dropside with tail-lift.
mrgasoil
Postby motorwise » Fri Mar 02, 2007 10:14 pm
if the use you're putting to doesn't need a tacho then you don't need to use it - just put one of the plastic discs in to protect the stylus
http://www.motorwise.net
motorwise
Postby jay » Fri Mar 02, 2007 10:15 pm
wont have a disc if its electric type..you have a smart card instead..
mk1 connect tourneo
jay
Postby motorwise » Fri Mar 02, 2007 10:19 pm
jay wrote:wont have a disc if its electric type..you have a smart card instead..
I knew that :oops: :wink:
motorwise
long time since I've used a tacho - you'd never guess though :lol:
motorwise
Postby jay » Fri Mar 02, 2007 10:24 pm
also some vehicles wont even let you turn the ignition on if you dont have your smart card in the tacho..there was a 6 week wait for smart cards as well
mk1 connect tourneo
jay
Postby mrgasoil » Fri Mar 02, 2007 10:29 pm
let me get this straight............. :?
If its mechanical its not a prob, if its electronic i need a smart card and thats a prob :?
Would the smart card come with the truck or is it a 6 week wait :? :?
mrgasoil
Postby Luke » Fri Mar 02, 2007 10:32 pm
card is also about £50 and only lasts 5 yrs :!:
Postby jay » Fri Mar 02, 2007 10:35 pm
smart card is for each driver..
mk1 connect tourneo
jay
Postby mrgasoil » Fri Mar 02, 2007 10:48 pm
Luke wrote:card is also about £50 and only lasts 5 yrs :!:
Dont know how to box quotes :oops: "jay said the cards are for each driver"
If this is the case surely if its an electronic tacho its in use all the time :?
Thats enough to put me off :cry:
:idea: Prob why they are so cheap......both 125ps 10ft dropsides with tail lift @90-100k @£4.5ish +vat
mrgasoil
Postby jay » Fri Mar 02, 2007 10:52 pm
dont worry if the van runs and starts without a card u can still use it for private use..(and i think if not towing)
But i have always put a card in a tacho even if i dont need to.(If stopped at least u can prove how long u have been driving for)Also u maybe able to get the digi tacho removed from a tranny van
mk1 connect tourneo
jay
Postby Luke » Fri Mar 02, 2007 10:52 pm
quotes are easy :wink: and jay is right :lol: 1 per driver :(
Postby motorwise » Fri Mar 02, 2007 10:53 pm
jay wrote:dont worry if the van runs and starts without a card u can still use it for private use..(and i think if not towing)
couldn't it also drop you in it for speeding? just a thought
motorwise
Postby mrgasoil » Fri Mar 02, 2007 11:00 pm
It's for business use, so if it has a tacho fitted i need to use it by law :?: :?
Luke..its multiple qoutes i dont get :oops:
mrgasoil
Postby chadmat » Fri Mar 02, 2007 11:03 pm
Sounds like you should stick with yer mk5!! :wink:
Sounds like trouble!
In a MK6 280 SWB semi hi!!!!
There you go! At last!
chadmat
Return to Transit Talk
