Ids
Ids
Postby t2myd » Sun Mar 06, 2016 6:13 pm
Does anyone with ids know if it's got the axel ratio 3.58. For a euro4 ,
Transit vantastic !!!!!!
t2myd
Re: Ids
Postby loot » Sun Mar 06, 2016 6:46 pm
It's not ids that has the 3.58 axle info, that is stored in the vans bcm.
Question should be are there any euro 4 vans with 3.58 axle :wink:
Ids map here
loot
Re: Ids
Postby t2myd » Sun Mar 06, 2016 8:47 pm
I was on phone to Martin on Friday he seems to think there is , I'd rather be sure before I fit the axel
t2myd
Re: Ids
Postby Airthies » Sun Mar 06, 2016 9:47 pm
Take a trawl through the viewtopic.php?t=37058 post and see if you can spot the van type and axle combo you're looking for?
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Re: Ids
Postby martynx » Sat Mar 12, 2016 10:39 pm
Regular IDS functions wont allow any final drive ratio selection in Euro 4 vans ( only Euro 3 like Mk6's ) so it would need programming in by someone who's up to speed with activating Cruise etc..
With that in mind , 3.58 is lowest you can put in the BCM from what i can see on Euro 4 & according to Loots recent experiments .. 3.58 was used in some 200ps Vans..
If you fit a 3.31 axle ( from a Euro 5) to a Euro 4 van then program in 3.58 axle & the Cruise Control will probably work OK.. if significantly wrong cruise may not work correctly & not at all in top gear :!: There is an axle ratio in the PCM as well but that doesn't seem as critical from a cruise functionality point of view .:D
martynx
Re: Ids
Postby motorman116 » Sun Mar 13, 2016 10:10 am
loot wrote:It's not ids that has the 3.58 axle info, that is stored in the vans bcm.
Yes, my 3.2 beast has :lol:
VIN Number:
Registration Number:
First Registration Date: 31.03.2008
Registration Country: GB
Type Approval Number (TAN): E1*2007/46*0248 / E1*2007/46*0264
Primary Features
Build Date: 22.01.2008
Vehicle Line: Transit 2006-
Cab Style: Regular Cargo Van
Series: 1.7-350L Series
Engine: 3.2L Duratorq-TDCi (200PS) - Puma
Transmission: 6 Speed Manual Transmission-MT82
Drive: RHD RWD
Axle Ratio: 3.58
Emission: Stage IV Emissions
Air Conditioning: Manual Air Conditioning
Territory: (+)"GB"
Paint: Moondust Silver (Metallic)
Interior Colour: Lichen
Interior Fabric: Tomy (G-C)
2008 3.2 5 pot diesel Ford Transit GLX Lwb, Hr
motorman116
Re: Ids
Postby loot » Sun Mar 13, 2016 10:40 am
8)
Ids map here
loot
Return to Transit Talk
