Cleaning out egr and inlet manifold
Re: Cleaning out egr and inlet manifold
Postby ned » Sun Jun 13, 2021 10:43 am
wicklabilly wrote:
trannyfreak wrote:How do you clean out the inlet pots on the head where the inlet bolts on to? Many thanks
that i wondered too as i was concerned that crud may fall into the combustion chamber :!:
I use a toothbrush on mine dipped into the cleaning solution, then wiped out with believe it or not baby wipes, if any bits do go into the combustion chamber surely they would get burnt off, my theory is that sh*t is going into the air flow anyway so some must make it past the valves.
If your going to do it buy some new gaskets.
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Return to Transit Talk
