Tdci converted to Tddi
Postby 77CN53 » Fri Nov 25, 2016 10:37 pm
Whats poeples toughts on converting a 125 tdci to 100 tddi. I know less power but looking at reliablity as sick off putting injectors in it and now i need a pump. :( :(
77CN53
Re: Tdci converted to Tddi
Postby ned » Sat Nov 26, 2016 12:17 am
If you need a pump your going to need new injectors and a fuel system flush about £1000 plus in parts alone, if you get the full TDDI van for less you'll have everything you need to swap them over. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby davenjodie » Thu Dec 22, 2016 1:23 am
Hi all, new to this forum,
I have a 2004 transit,
It the 2l tddi I think
I wanna put a 2l tdci 130ps engine in it, I already have the full donor car (2005 mondeo)
Do I need to swap everything over? I.e. Engine loom,dash loom??
Any help would be greatly received
davenjodie
Postby paul2012 » Thu Dec 22, 2016 10:22 pm
davenjodie wrote:Hi all, new to this forum,
I've done this conversion from TDDI to TDCI using a 2.0 TDCI 130ps engine from a Mondeo mk3 - Vid here :arrow: https://www.youtube.com/watch?v=XEpVXomtL6g
See my project thread here :arrow: viewtopic.php?f=27&t=150664
You'll require the following part's from a mk6 2.0 TDCI 125ps....
Dash loom
main engine bay loom
Engine subloom
TDCI PCM
Coolant hose that runs from EGR cooler to interior heater/water pump
Vac solenoids for EGR & turbo
If you van is a 75ps TDDI you'll also require...
Intercooler with all associated hoses
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby davenjodie » Fri Dec 23, 2016 4:38 am
Dash loom
Engine subloom
TDCI PCM
Thank you Paul, big big help
davenjodie
Postby davenjodie » Sat Dec 24, 2016 10:13 pm
Dash loom
Engine subloom
TDCI PCM
Hi paul, when you say pcm? Is that the ecu?
And sub loom? Is that engine fuse box etc
Thanks in advance
davenjodie
Return to Transit Talk
