Dump valve
Dump valve
Postby jonnyshag » Sat Sep 17, 2005 10:34 pm
I had a dump valve fitted to my transit turbo diesel, it worked but very costly :D
jonnyshag
Postby FredTransit » Sun Sep 18, 2005 9:28 am
Remind me, what exactly does this do and how does it improve performance? I had heard they were now 'unfashionable' with the boy racers, so can't be that important!
FredTransit
Mk2 Trannyist
Postby madmark » Sun Sep 18, 2005 4:00 pm
:shock: frd you need to come to mk then on a sunday night! :lol: it makes a ppsssssssssssssssssssssssssss sound when you change gear on a turbo only car! :D
Postby FredTransit » Sun Sep 18, 2005 11:47 pm
Yeah, I have heard the noise it makes, a local kid used to have an XR3i, but I wondered what ithe dump valve is for. Turbo trannies don't have them, or is that just a diesel thing?
FredTransit
Mk2 Trannyist
Postby MrMPuk » Mon Sep 19, 2005 12:33 am
A dump valve is to stop turbo lag by helping it to continue to spin whilst changing gear. But to be honest I think they are more for show and can't imagine it will really make much difference on a diesel.
Postby jonnyshag » Mon Sep 19, 2005 1:05 am
Yeah to be honest it didnt make much difference ,but sounded really good especialy coming from a transit diesel, i also had a turbo gauge fitted on the dash which came in useful :)
jonnyshag
Postby madmark » Mon Sep 19, 2005 2:07 am
what is it boosting at mate??????is it standard ??????? :D have you got a intercooler??????
Postby jonnyshag » Mon Sep 19, 2005 10:20 pm
when i had it first fitted it was about 8psi but there were a slight leak , after i sorted theleak out we turned it up to 12psi
jonnyshag
Postby madmark » Tue Sep 20, 2005 1:20 pm
that good going mate ! when you get chance can get some more picks of the van in the gallery i would like to more ,you dont see many twin wheelers like yours! :D
Postby snakemaster » Sat Sep 24, 2005 9:22 pm
Block the wast gate pipe and you can run 20/30 psi boost = lots more power + less mpg when you gun it and set your dump valve to 28 psi
this will work good i have done this on a few TD
snakemaster
Postby UK_ANDY » Sat Sep 24, 2005 10:25 pm
anyone know anything about this??? propane injection .......propane has the same effect on diesel's as nitrous oxide has on petrol engines apparentley .... http://www.dieselperformanceproducts.com/home.html
some tech info can be found here............
http://www.mrsharkey.com/lpg.htm
old ford's never die they just go faster
Click here to vote for the forum in the Ford top 50 sites!!
UK_ANDY
Postby bortaf » Sat Sep 24, 2005 10:32 pm
Propain is LPG aint it?
There have been kits about for ages sposed to give 25% power hike or 25% ecomony rise i think it was?
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby 100ps_drw_hicube » Sat Oct 15, 2005 8:09 pm
what sort of dump valve did you have fitted ? do they make a specific one for a transit? i havent seen any :( i want to get one for mine
100ps_drw_hicube
Transit Abuser!!
Postby jonnyshag » Sun Oct 23, 2005 11:46 am
Hi ,i cant remember the make of the dump vavle , i got it done by motorsport delvelopment in blackpool
jonnyshag
Postby stevew » Tue Oct 25, 2005 2:52 pm
They are not made for specific vehicles. All it is is a short piece of tubing with an over presure valve on the side. The tricky bit is getting the correct bits of tubing to connect it and if you've got something rare and Japanese then it all has to be anodised blue aluminium :) It shouldn't be a problem on the 2.5 td transit engine as there is a long section of tubing between the turbo and the inlet manifold to fit it. I wouldn't have thought it would make much difference on a diesel though. On a petrol engine when you lift off the throttle to change gear the air inlet is effectively completely blocked and the turbo pressure quickly builds to very high levels slowing the turbo. This just isn't the same in a diesel because there is no throttle.
All the same the sound would be cool 8) or at least unexpected! :lol:
Steve
stevew
Return to Transit Talk
