Whole van shudders
Whole van shudders
Postby Keemo » Fri Jan 13, 2017 9:38 pm
I have a MK6 transit and the whole van sort of jumps and shudders when pulling off in first gear and reversing. Any ideas?
Sent from my SM-G900F using Tapatalk
Keemo
Re: Whole van shudders
Postby ned » Fri Jan 13, 2017 10:34 pm
Could it be a failing dmf. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby Keemo » Sat Jan 14, 2017 1:32 pm
Thanks mate, what's a dmf?
Keemo
Postby ned » Sat Jan 14, 2017 1:40 pm
DMF: Duel mass flywheel.
Are all the engine mounts ok?
My van sometimes shudders in first when pulling off, I was hoping with your post somebody would say if its a symptom of a failing dmf or not so I can find the fault with mine :lol: N
ned
Postby Keemo » Sat Jan 14, 2017 1:45 pm
Well I've just had a new master cylinder and the guy recond he'd had a look at the flywheel and it was fine (I'd told him to change anything that needed changing) so I don't think it's that.. perhaps the engine mounts? I've had a couple of friends who've had the same issue but no one really seems to know what the solution is.
Keemo
Postby ned » Sat Jan 14, 2017 1:49 pm
Front wheel drive or rear wheel drive :?: My lower engine gearbox mount is buggers so it might be worth checking that.
Bloody vans. N
ned
Postby Keemo » Sat Jan 14, 2017 3:26 pm
Fwd mine is mate. Don't get me started I've just pulled the mat up in the front and was greeted with a nice view of the road ImageImage
Keemo
Postby ned » Sat Jan 14, 2017 3:44 pm
Nice, some cutting and welding and welding and more cutting and welding :lol: I predict you have a Southampton built van there :wink: N
ned
Return to Transit Talk
